Old 06-04-2013, 11:15 AM   #1
wowzer's Avatar
Landing Gear
Is there a limit switch to stop from over extending or retracting the landing gear?
wowzer is offline   Reply With Quote
Old 06-04-2013, 11:25 AM   #2
Dave_Monica's Avatar
You didn't state what your camper is, but on our Rockwood, there's a mechanical stop on retracting that will easily blow the in-line 30A fuse if you run into it at full motor speed. I can't say about limiting the extension...I'd expect that there'd be a mechanical stop somehow to prevent really bad things to happen.
Dave
Old 06-04-2013, 11:30 AM   #3
Fulltime family RVer
Good question- I have the same one for my Sabre. I'm interested to hear the responses.
ependydad is online now   Reply With Quote
Old 06-04-2013, 11:39 AM   #4
Owner/Operator
RodeoGeorge's Avatar
I run the landing gear up to find the upper limit, bring it back down about 1/4", and then put a wrap of red tape around the inner leg so that I have a reference to avoid hitting the stop and blowing the fuse.
Besides blowing the fuse, you risk damaging the gears when you reach the limits, and replacing the gear set in the landing gear is NOT fun.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 06-04-2013, 09:21 PM   #5
wowzer's Avatar
Sorry for lack of info....I have Sabre 34reqs6. To add to the Q..does the stability of the landing gear increase the less the extension are extended?
Old 06-04-2013, 09:57 PM   #6
Seeing that the construction of the landing gear is a tube inside a tube inside a tube, the less they're extended, the more stable they are. I use 8x8x4" blocks to reduce the extension. I've installed the SteadyFast stabilizers to reduce camper movment further.
Dave
