05-20-2016, 08:24 AM
Landing Gear Switch
I have a 2015 5th Wheel wildcat. The other day the switch popped when retracting the landing gear, it will still extend. I've looked at a few places online for a replacement switch but no luck. Camping world has a full replacement housing, but the switch is able to come out so i just want to replace the switch. Does anyone know where i can get a replacement ? TIA
2015 Forest River Wildcat 312BHX
Reese Goosebox With 5th Airborne Air Ride
TV 2013 Ford F250 Crew Cab 6' Short Bed 6.7 Diesel
Air Bags, B&W Gooseneck
Days Camp 2015 (Since 6/23) 5
"Onward Thru The Fog"
05-20-2016, 08:37 AM
**HERE** is one source.
**HERE** is another.
There are many places that sell DPDT rocker switches.
05-20-2016, 08:39 AM
Just super glue it back in.
05-20-2016, 08:40 AM
The confusing part for me was that the DPDT switches i found had 6 contacts on back. The current switch only has 4 contacts with only 4 wires coming out. Then it has some type of jumpers i haven't seen before.
05-20-2016, 08:55 AM
SMN8, what do you mean by "the switch popped"? Did it make a noise? Did it come apart? Did it pop out of its housing?
05-20-2016, 09:03 AM
The jumpers just complete the circuitry to allow the DC motor for the landing gear to be run in both directions.
Making 'jumper' wires with crimped terminal ends (via the same terminals on another switch with six terminals) will accomplish the same thing
05-20-2016, 09:06 AM
The 4 wire switch has internal jumpers that do the same function.
You need 2 wire to landing gear. 2 wires from power source.
B and B
05-20-2016, 09:11 AM
To add to what I said above... (per your photo)
With the DPDT switch pushed one direction, the center red (+) feeds the pink wire on the end of the switch and the center black (-) makes connection to the end black.
With the switch pushed the other direction, the center red (+) feeds the black on the end of the switch (via the jumper) and the center black (-) feeds the end pink (via the jumper) to run the motor in reverse.
05-20-2016, 09:13 AM
True, some 4 terminal DPDT switches do have internal jumpers.
His photo shows them on the exterior and he indicated that is what confused him.
05-20-2016, 09:33 AM
Thank you all for the replies. So i just need to get a 4 terminal switch. Easy.
When i say "pop" it sounded like a fuse tripping. Normally when switch is pushed up or down it will click and you can fill it. Since the "pop" the switch is perfect in the down, but on the up its free.
When i first took delivery i did have to replace a few fuses back to back when using the landing gear switch. So now it all adds up and the switch could have been defective from the beginning.
05-20-2016, 09:40 AM
Yes, the 'easy' replacement is to find another DPDT switch with 4 terminals that has jumpers (external or internal) such as what you currently have.
A six terminal DPDT will work fine though.
It would require you to make your own jumpers and as such, would not be the simple plug and play replacement mentioned above.
05-20-2016, 09:41 AM
Thank you all for the fast replies and help with this. Much appreciated
05-21-2016, 11:35 AM
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
