Old 05-20-2016, 08:24 AM   #1
Landing Gear Switch
I have a 2015 5th Wheel wildcat. The other day the switch popped when retracting the landing gear, it will still extend. I've looked at a few places online for a replacement switch but no luck. Camping world has a full replacement housing, but the switch is able to come out so i just want to replace the switch. Does anyone know where i can get a replacement ? TIA
Name:	2016-05-16 22.14.06.jpg
ID:	108432   Click image for larger version
Name:	2016-05-16 22.14.16.jpg
2015 Forest River Wildcat 312BHX
Reese Goosebox With 5th Airborne Air Ride
TV 2013 Ford F250 Crew Cab 6' Short Bed 6.7 Diesel
Air Bags, B&W Gooseneck
Days Camp 2015 (Since 6/23) 5
"Onward Thru The Fog"
SMN8 is offline   Reply With Quote
Old 05-20-2016, 08:37 AM   #2
Pickin' & Campin'
**HERE** is one source.
**HERE** is another.
There are many places that sell DPDT rocker switches.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-20-2016, 08:39 AM   #3
Just super glue it back in.
Old 05-20-2016, 08:40 AM   #4
The confusing part for me was that the DPDT switches i found had 6 contacts on back. The current switch only has 4 contacts with only 4 wires coming out. Then it has some type of jumpers i haven't seen before.
Old 05-20-2016, 08:55 AM   #5
Mr. Dan's Avatar
SMN8, what do you mean by "the switch popped"? Did it make a noise? Did it come apart? Did it pop out of its housing?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 05-20-2016, 09:03 AM   #6
Pickin' & Campin'
The jumpers just complete the circuitry to allow the DC motor for the landing gear to be run in both directions.
Making 'jumper' wires with crimped terminal ends (via the same terminals on another switch with six terminals) will accomplish the same thing
Old 05-20-2016, 09:06 AM   #7
B and B's Avatar
The 4 wire switch has internal jumpers that do the same function.
You need 2 wire to landing gear. 2 wires from power source.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 05-20-2016, 09:11 AM   #8
Pickin' & Campin'
To add to what I said above... (per your photo)
With the DPDT switch pushed one direction, the center red (+) feeds the pink wire on the end of the switch and the center black (-) makes connection to the end black.
With the switch pushed the other direction, the center red (+) feeds the black on the end of the switch (via the jumper) and the center black (-) feeds the end pink (via the jumper) to run the motor in reverse.
Old 05-20-2016, 09:13 AM   #9
Pickin' & Campin'
True, some 4 terminal DPDT switches do have internal jumpers.
His photo shows them on the exterior and he indicated that is what confused him.
Old 05-20-2016, 09:33 AM   #10
Thank you all for the replies. So i just need to get a 4 terminal switch. Easy.
When i say "pop" it sounded like a fuse tripping. Normally when switch is pushed up or down it will click and you can fill it. Since the "pop" the switch is perfect in the down, but on the up its free.
When i first took delivery i did have to replace a few fuses back to back when using the landing gear switch. So now it all adds up and the switch could have been defective from the beginning.
