Old 08-23-2017, 08:20 PM   #11
Yea, I'd love to have American tires with a higher weight limit. Tks
Cardinal camper is offline   Reply With Quote
Old 08-23-2017, 08:26 PM   #12
First off, I'll get the China tires off plus upgrade to a more substantial tire with higher rated load range.
Old 08-24-2017, 10:13 AM   #13
drittal's Avatar
Larger Size Tires?? Yes or No
Do they make ST tires in the size you are looking at or are you switching to LT? A quick search I did only came up with wider trailer tires only came with a taller aspect ratio as well.
drittal is online now   Reply With Quote
Old 08-24-2017, 11:17 AM   #14
I think I'm going with Goodyear Endurance and they do have the 245 and 255 in ST.
Old 08-24-2017, 01:11 PM   #15
drittal's Avatar
I guess they have more sizes available than they show online?
Old 08-24-2017, 03:54 PM   #16
Thinking about replacing original tires on 2017 Sandpiper. Currently have 235-80R-16. Would like to go up to 245 or 255. Is this good idea or not? I have the rims to handle the larger tires and would love to have the piece of mind of higher ply tires. Your thoughts?? Tks!!!
If you decide to jump a load range or two, don't forget to change the valve stems to conform to the new tire pressure.
Trawlerphil is offline   Reply With Quote
Old 08-24-2017, 08:01 PM   #17
Bigger Tires
Cardinal Camper,
Good idea to get the China tires off your RV. Consider going to a Light Truck tire. A LT tire may be put onto an RV or go on a passenger automobile. However, an ST tire states on the sidewall, ONLY to be used in trailer service, or some type of warning. Why is this, well it is all about testing. ST's are manufactured with little to no safety standards, where the LT's are run through a multitude of tests just to be able to be manufactured. Where do you want to spend your money? Stay with the ST's and risk safety, longevity, and listen to all the multitude of excuses as to why YOUR tires did not hold up. Do some research and discover what no ST tire manufacturer wants you to know. With 16" rims you should find whatever size you want to fit your needs. Consider Nokian tires at Discount tire. Research them and see why I say this, I own 4, will never own another ST tire. To your original post ... yes you can go larger, just go larger LT !
cseeger22
cseeger22 is offline   Reply With Quote
Old 08-24-2017, 08:48 PM   #18
China Bombs gone. I went to Michelin XPS LT tires. Had to use 245 75 16 to replace my 235 80 16's in order to get the load rating I needed. My only issue was a clearance on the slide mount on the right side of my Crusader. Had to modify it a little to be sure it didn't rub. Tires are great. A little costy but they are steel sidewall steel tread belt. Designed for commercial vehicles and are rated to be capped 3 times, not that I ever intend to cap them, but tough as you can get. 3 years without issue. Oh yeah, all steel valve stems, and TPMS monitor an absolute.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is online now   Reply With Quote
Old 08-24-2017, 09:25 PM   #19
5er_tom's Avatar
After going to LT tires keep an eye on your wheel rims. If they are Fancy aluminum rims they may not be able to handle the added stress created in tight turns. The ST tires are more flexible on the sidewall than LT tires.
I cracked three rims and therefore needed to replace all of them with steel rims.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 08-24-2017, 09:34 PM   #20
rsdata's Avatar
ST Vs LT tire debate
some published info here...
https://rvingwithmarkpolk.com/2012/1...s-vs-lt-tires/
This article is a little dated ( 5 years old) because as most of us know, some ST tires are rated for more than 65 MPH now.
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
tire, tires
