Old 09-22-2012, 08:27 AM   #21
Road-King's Avatar
Originally Posted by TheSasks View Post
55 -58mph.
TheSasks,
I'm just curious, but do you still run the "C" rated tires? The reason I ask is I'm planning on going up to a "D" or maybe even an "E" rated tire when I change them out. I wouldn't think the stiffer sidewall would make that much of a difference.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-22-2012, 08:55 AM   #22
Wanna Be Camper
SaskCampers's Avatar
Russ,
I still have the factory installed Duro LR C tires all at a TPMS monitored 50 psi (they have over 12,000 miles now) but they are going to be replaced with LR D or E tires in the spring. So ya it's not the tires. The one interesting thing is the first summer we took a 4000 mile trip to Ontario via the Canadian route and there were a couple places that there were huge bumps that were not marked one in particular I hit hard enough that it wedged the rear screen door in the frame but there was not a single thing out of place in the trailer. That episode caused me to sing the praises of the torsion suspension but then this year with far better roads IMO we had all this damage so I am at a loss to explain it. When Dunnnc made his initial post about his shock install I was pretty vocal about not requiring it on these units mostly from a handling perspective as our trailer tracks like it's on rails but I am now of the belief that his mod may indeed help the issues we had as much if not more than the handling. I am not saying it does not aid the handling as in a 5ver with the extra height as it probably does. So I do stand corrected in my opinion of the shock install.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-22-2012, 08:57 AM   #23
Wanna Be Camper
Originally Posted by DDC View Post
This is the first trailer I've had with torsion suspension and I find it really good I like how it is lower I feel the lower centre of gravity helps stabilize the trailer, as for stuff breaking off with the ride I'd be more inclined to check tire balance than blame the torsion suspension.
Sorry, all my tires were just balanced prior to departure this summer.
John & Deb
Old 09-22-2012, 01:14 PM   #24
daydreaming about camping
jeeplj8's Avatar
Originally Posted by Road-King View Post
TheSasks,
They can. I own a wakeboat, lots (way to much) money on a steel trailer. Torsion axles. Lots of guys to taller tires, lower profile and therfore shorter sidewalls. They ride rougher.
Many guys have gone to higher load range as well, again they can tell the trailer rides rougher.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
axle
