Old 10-01-2012, 07:45 AM   #11
Rugged Brown's Avatar
I suppose I'll have to bolt that second axle back onto the frame now and buy the beer when I arrive at the campground.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-01-2012, 07:48 AM   #12
Sure, leave it at home, who needs another tire/wheel when you have 2 or 4 good ones. It will also give you a chance to cuss yourself for being a dumb a-- for leaving it home while you're sitting on an interstate with a flat. It also helps elevate your blood pressure, which keeps the doctors employed.
Old 10-01-2012, 07:55 AM   #13
AquaMan's Avatar
While on the subject of spares, how many have a lug wrench that actually fits their trailer?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-01-2012, 07:56 AM   #14
We are now on our 4th trailer. #3 was a Sunline 25'TT, that DID NOT come with a spare and did not (think to) add one! In 25 years of trailer camping, we've only needed a spare once and guess on which unit that was.
As it turned out, we were lucky as we were able to hobble into the CG and AAA RV were able to help us out with a replacement tire&wheel loosing little quality camping time.
We will not leave home with out one again!
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 10-01-2012, 08:06 AM   #15
jimh's Avatar
i usually carry two spares.
i thought i had a lug wrench that fit until i had my first flat; turned out it was big enough to grab the decorative part of the lug nut and twist that part around the nut. the next smaller was too small. (chiseled off the stainless decorative cover of the nut and fit the smaller size socket onto it).
i would always pull up on the nuts before i left and had no problem. when i really had to get on the wrench, found out it would not fit. i would recommend actually unscrewing a nut and reinstalling it before ur first trip. that way u should have some assurance it will work.
jimh is offline   Reply With Quote
Old 10-01-2012, 09:24 AM   #16
Yukon Don's Avatar
I tested out my four-way wrench and found it's too thick to fit between the nuts and the wheel hub. Will be adding an appropriate deep socket and breaker bar to my tool kit.
To the OP: I'd definitely recommend carrying the spare.
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 10-01-2012, 10:34 AM   #17
jimh's Avatar
that first flat was in 2005. had forgotten that my wrench would not go all the way in. i was able to get to the nuts when i took chiseled off that decorative part. also experienced not being able to get down on the lug nut. that is probably why i was spinning the decorative part so that it looked like i had rounded off the nut. i have a thin walled deep socket and breaker bar that i use now. still use the 4 way to spin them on and off.
if ur not familiar with the decorative nuts, if u have the end covered, there is a stainless cover over the nut. they may appear to be solid but they aren't.
Old 10-01-2012, 01:46 PM   #18
lindy's Avatar
X2 on the 4 way star bar socket being too big to fit into the rim hole and over the lug nut, I have the stock F.R. aluminum rims, so there's a deep well socket and 18" breaker bar in the storage box.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-01-2012, 02:47 PM   #19
DDC
DDC's Avatar
If you leave the tv spare at home to you will gain even more than a hundred pounds, what the heck if you leave the whole family just think of the extra capacity. (sorry I just couldn't resist)
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 10-01-2012, 03:13 PM   #20
caper's Avatar
Why not go one step farther and make the trailer into a hover craft. then you would not need a spare tire or even have to grease the bearings. With no resistance you could tow a large trailer with a small car.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
