Old 01-16-2013, 01:09 PM   #21
acadianbob's Avatar
Originally Posted by pwrstroke2012 View Post
Called around local tire shops and the Maxxis 225/75R15 D were $576 mounted balance and OTD. So other question is my trailer is 7,000 UVW, my current tires are C range, should I go with D or E range? I believe D would suffice. Would I have to change rims if I went with D or E?
I would think the Range D would be plenty. The limiting factor might actually be your rims. Are they rated for the pressure that you would be running? D rating would be nice if you can do it. It would give you that extra margin on a long, hot towing day.
I ran a set of Marathons for 5 years and 30M miles. No issues whatsoever. They looked fine too. No cracking. But I decided to replace them at that point for peace of mind and safety. I did replace my C's with D's also.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-16-2013, 01:31 PM   #22
Herk7769's Avatar
Replaced my Carlisle C rated tires with Marathon D rated tires. MAKE SURE you replace the low pressure rubber stems with high pressure steel or brass stems.
Rubber stems max out at 50 PSI. Brass/steel stems can go to 100 PSI.
HAM CALLSIGN - KC3FFW
Old 01-16-2013, 04:26 PM   #23
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
I just went by our rv and check the tires. The number on the side said "2109"...so that means there were made May 18-25, 2009. They still look good, but I will keep and eye on them.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 01-16-2013, 04:48 PM   #24
Herk7769's Avatar
So in May they will be 4 years old. If you run them regularly and cover when not in use you should get 2 more years service out of them.
Start saving for your replacements in a "tire jar" now and you will be ready to go when they "age out".
Old 01-16-2013, 05:05 PM   #25
acadianbob's Avatar
Yep, and it also allows you to attach a tire pressure monitor.
Old 01-16-2013, 05:08 PM   #26
iluvlcy's Avatar
Silly question, where do I get replacement tires? My rv dealer? Tire shop?
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 01-16-2013, 05:28 PM   #27
Commercial Member
huntr70's Avatar
Yes, and yes....
We get ours from a local tire dealer, so just skip the middleman and go right to the tire shop....
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 01-16-2013, 05:34 PM   #28
camper1999's Avatar
I go 3 to 4 years and make sure I inspect them before each trip for cracks etc. It is just not worth it to push the life of the tire considering the damage it can cause.
2011 GMC 2500HD Diesel
Old 01-16-2013, 06:19 PM   #29
Herk7769's Avatar
I bought my Goodyear Marathons at my local Goodyear dealer. He does not stock ST tires so I had to order them.
Since he had to call the warehouse anyway, I requested the dealer to make them check for a set of 4 ST tires with the tire code "MD" (Gadsden, AL) and date stamped less than 1 year old.
Ordered on July 16 2010, I got not only 4 ST tires made in Alabama but a set that was made between June 21 and June 27 2010.
Now THAT is service.
Old 01-16-2013, 07:28 PM   #30
Graduate Member
RoadTrip's Avatar
This info works on a class c, too, right?
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
