Old 07-10-2014, 05:09 PM   #1
Lift Jack motor Cardinal
The lift jack motor burned out on my Cardinal fifth wheel. Does anyone know who has replacements?
C1v1leng is offline   Reply With Quote
Old 07-10-2014, 10:15 PM   #2
Dave_Monica's Avatar
I found this link when I searched... Fifth Wheel Landing Gear :: Stromberg Carlson
I thought Cardinals have hydraulic systems or is that just for the slides?
Dave
Old 07-11-2014, 08:06 AM   #3
Thanks,
Thats just what I needed.
The Hydraulic system is just for the slides on my unit.
Old 07-11-2014, 03:03 PM   #4
jackdn0610's Avatar
I know it might be a little more expensive, but you since you are going to replace the landing gear you might consider having a motor put on each leg instead of the bar across. That way you can control each leg independently. It would also entail adding a second switch to control the other motor.
Jack & Jo Neihouse
Grass Valley, CA
2014 Cardinal 3450RL
2011 Ford F350 SD DRW
F.R.O.G. Members
jackdn0610 is offline   Reply With Quote
cardinal
