Old 08-22-2013, 09:33 AM   #1
jeepman71's Avatar
Lift kit install on 8289WS
I am going to install a lift kit on my 8289WS. Looking for suggestions on lifting the trailer enough (app. 3 inches) to install the kit. I am thinking of pulling the trailer up on blocks with one axle similar idea to the tire changing ramps. Is this too much weight on one axle for the amount of time it takes to drop the axle and install the lift blocks? The alternative is to lift the trailer on the frame between the axles and place my jack stands on the frame cross rails fore/aft of the axles. I think this would work just fine because I don't have to remove the axles. I would prefer option 1.
What do you think?
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
Old 08-28-2013, 11:08 AM   #2
type in Dexter lift kit installation and you should be good to go. Serge
Mac rv is offline   Reply With Quote
Old 08-28-2013, 11:34 AM   #3
Brother Les's Avatar
What do you think?
imo It will be fine, the axle will hold just fine. use wide board ramps to lift one axle about two-three inches staggered height. Then if you have them put out chalks and stabilizers down and sissor jacks under frame for more stabilization, and not really for 'lift'. Then pull the tires off your lifted axle.
Brother Les
Old 08-28-2013, 04:34 PM   #4
Dave_Monica's Avatar
Here's a link to the Dexter lift kit installation that 'Mac rv' referred to... http://dexteraxle.com/i/u/6149609/f/...x_Lift_Kit.pdf
Dave
Old 08-28-2013, 05:04 PM   #5
Witch Doctor's Avatar
Jeepman71, I have the same model as you do, can you please tell why you would want to install a lift kit to the axle? I find that I have plenty of clearance to my wheel well even with putting on Marathons D rated tires. Just being curious .
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-28-2013, 05:45 PM   #6
jeepman71's Avatar
Thanks for the link Dave_Monica.
gljurczyk, I am installing the lift kit because the clearance is limited and getting smaller. In the pic below you can see there is barely enough room for two fingers. This weekend there is barely enough room for one. I am taking it to Forrest River in October. At that time they can determine if I need new axles. I will like the lift kit because it sets a touch low on my truck anyway.
ID:	38825   Click image for larger version
Old 08-28-2013, 09:05 PM   #7
I'm a little surprised that the lift kit doesn't include any extra cross bracing between the axle spacers. I've attached a photo of the axle mounting/spacer arrangement of our 8280WS...I believe that your 8289WS will be the same. I'm no structural engineer but adding a 3" spacer below the existing ones and no extra cross brace doesn't seem right to me.
Dave
Name:	axle spacers.jpg
Old 08-28-2013, 10:01 PM   #8
B and B's Avatar
I have the 8289WS as well. After running 2 lane roads up to Grand Bend and Kincardine for a week away I smell a rubber type smell. Tires never are hot, warm. Running 4 lane 401 for 2 hours to Rondeau the rubber smell is less. We have 1200 km on the trailer now. Wondering if anyone else has this rubber smell, assumption is the axle working as it should. Is there a break in period for the axles?
jeepman I was under my rig installing a Sirus antenna lead and noted pretty tight clearance as well but not as bad as you have on yours. Please keep us updated on the axle situation for the 8289.
Mine was built Nov 2012 and is the mid production modified front fibreglass with more headroom.
My trailer weight is 8800 lbs, pin weight is 1750 lbs all with specs of 9500 lbs gross, max pin for the hitch of 2000 lbs.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-28-2013, 10:10 PM   #9
Have you checked the top of the wheel wells for tire rub?
Dave
Old 08-28-2013, 10:52 PM   #10
jeepman71's Avatar
I do agree with your thoughts Dave. I am going to use some 1/4x1 1/2 flat metal and drill and mount it to the bolts to help stabilize it laterally and drill the lift block on the bottom to bolt up through the axle mounting bracket and the lift block. This should help. I don't think it would be any more side stress than longer shackles on spring lifts. I would also think the axle is going to help in the way of a cross brace.
