Old 05-07-2013, 11:59 AM   #1
Old Enough to Know Better
gasman6674's Avatar
Lifting a trailer
What is the best way to jack up you trailer to service tires etc?
I read somewhere (I think on here) that its best to lift the frame of the unit. I did that when I serviced my wheel bearings and it worked but didnt seem to be stable. Is it a big nono to lift the axle?
Thanks for the input
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 05-07-2013, 12:10 PM   #2
Fulltime family RVer
Subscribed. I have 4 new tires coming and need to know the same. Pictures preferred.
This past weekend, I simply used my Lynx levelers to drive up onto and let one tire hang in the air. Problem with that was that I needed to get up really high to beat the Equalflex suspension (like 6 1/2"). And worse- when I tried it on the other side, my interlocking blocks slipped when I tried to go up 2-high and cracked one. I couldn't get them to interlock right after that and couldn't get the passenger side of the camper high enough to let me tire hang.
I now have 2 jacks- just still don't know what I'm doing.
ependydad is online now   Reply With Quote
Old 05-07-2013, 12:37 PM   #3
First off, you need 4 jack stands capable of holding the weight. If you have spring suspension, you can jack directly on the spring between the U bolts and place the jack stand directly in front of the front spring hanger on the frame. Same for the rear except place the jack stand directly behind the rear spring hanger on the frame. If you have torsion suspension, jack between the axles on the frame or on the steel tube frame work the suspension is mounted on and place the jack stands on the frame or suspension framework. DO NOT JACK ON THE AXLES on a torsion axle.
Picture shows just the corner of a jack stand in the lower rh corner.
Name:	Left front.jpg
Old 05-07-2013, 12:48 PM   #4
gasman6674's Avatar
I have spring suspension not torsion so placing the jack under the spring and axle is ok If I am reading you correctly.
Thanks for the reply
Old 05-07-2013, 12:50 PM   #5
Yes, just jack between the U bolts and make sure you block the other wheels until you get one side on jack stands.
Old 05-07-2013, 12:50 PM   #6
Sorry to say this- how do I know which type id axles that i have?
Old 05-07-2013, 12:53 PM   #7
If you have 4 springs you have a spring suspension, if there are no springs you have torsion.
