11-02-2016, 12:36 PM
LionsHead wheel PSI rating
I e-mailed about the PSI rating on the aluminum wheels on my 5er.
Here is her response in the E-mail exchange. Good customer service.
Sent from my iPhone
Begin forwarded message:
> From: Brenda Speicher <bspeicher@lionsheadtireandwheel.com>
> Date: November 2, 2016 at 11:02:48 AM CDT
> To: Chetty Cherry <cherrychetty4@gmail.com>
> Subject: RE: LionsHead Reply
> The wheel is rated with a load carrying capacity and your valve stem is rated for the psi, your 15x6 6 lug wheel can handle the upgraded tire, yes you will need to be sure that you upgrade to a valve stem that an also handle the higher psi of the upgraded tire.
> As I am sure you are aware although you are putting a tire on with a higher load carrying capacity, you are still limited to the weakest link in your load carrying capacity which would be your axle, as long as you are not overloading the unit you should not have a problem with the wheel, and as long as you upgrade your valve stems to match the psi of the tire you should not have an issue their either.
> Does that answer your question?
> Brenda Speicher
> LionsHead Specialty Tire & Wheel
> PH:574-533-6169 x129
> Fax: 574-533-6761
> CONFIDENTIALITY NOTICE: This email (including any file attachments) is for the sole use of the intended recipients - not necessarily the addressees - and may contain confidential and privileged information that by its privileged and confidential nature is exempt from disclosure under applicable law. You are hereby notified that dissemination, disclosure, distribution, duplication, or other use of this transmission by someone other than an intended recipient or an intended recipient's designated agent is strictly prohibited. If you are not an intended recipient or believe you have received this transmission in error, please notify the sender
> From: Chetty Cherry [mailto:cherrychetty4@gmail.com]
> Sent: Wednesday, November 02, 2016 8:31 AM
> To: Brenda Speicher
> Subject: Re: LionsHead Reply
> Thank you for your prompt response. My main question is PSI rating vs: wheel rating. In other words if I upgrade to an E rated tire at 100 PSI are these wheels rated 100 or more with the proper stems?
> Thank you,
> Chetty
> Sent from my iPhone
> On Nov 2, 2016, at 7:16 AM, Brenda Speicher <bspeicher@lionsheadtireandwheel.com> wrote:
> Good morning Chetty,
> The wheels have a load carrying capacity, the tire and the valve stem have a psi rating. If you upgrade your tire you will need to be sure that you also upgrade the valve stem to one that will handle the psi of the upgraded tire.
> Does this answer your question?
> Brenda Speicher
> Fax: 574-533-6761
> Passion, Pride, & Performance
> 827 E. Lincoln Ave.
> Goshen, IN 46528
2017 Puma 297RLSS
11-03-2016, 11:20 AM
That's the same thing they told me when I contacted them.
I've contacted them twice and have been well pleased with their service both times.
Gotta go campin!
11-03-2016, 11:30 AM
What is the PSI rating so I can mark it on the Rims? Youroo!!
11-03-2016, 12:08 PM
I have their 8 lug 16" rims and I had emailed and asked if they would withstand the higher pressure F load range (95psi) and I received a similar response, that the rims would handle it but to make sure the valve stems were replaced with ones that would.
2016 Vengeance 3062V - SOLD
2013 Ram 3500 4x4 CC DRW 6.7L
2015 Harley CVO Limited
2015 Harley CVO StreetGlide
11-03-2016, 12:41 PM
A while back I got a similar response. They don't put a PSI rating on the wheel but they do stamp it with the maximum load. Look at the max load for your tire and as long as it's equal to or less than the stamped value you're good to go up to thePSI on the tire.
BTW, the eight lug 16.5" wheel is good for 3,960 pounds which I think is "G" load at 110 PSI.
Bobcat Aluminum Wheel
BIRDS AREN’T REAL
11-04-2016, 09:23 PM
Lions Head
The psi rating for the rims are on the inside of the rim You have to remove the tire to see it. Mine was a heavy duty rim on my 5er rated at 110 psi but most are not. Also mine was a 8 lug I believe on 8000 lb axles. If you get a tire rated for 110 psi and run 100 psi you have less carrying capacity and the tire is a waste
11-04-2016, 09:37 PM
Uhhh emm-dee, is that 16.5" wheel a typo perhaps? I haven't seen 16.5 inch diameter wheels on anything in many a year.
2011 Flagstaff 831 RLBSS
11-04-2016, 10:38 PM
Yes, a typo. Should be 6", (meaning width).
BIRDS AREN’T REAL
11-05-2016, 02:36 AM
I'm not a tire expert by no means, but if you change the valve stem to the bolt in high pressure stem you should be able to run that up to 110 PSI maybe WMTIRE can answer that... Mine are stamped 65 PSI so I was able to move up from a "C" rated to "D" rated which gave me a cushion that I didn't have when I bought it....
Coachmen M/H
Concord
2018 / 300 DSC
11-05-2016, 11:04 AM
145 psi for you, you have to carry all those rocks and booze
Coachmen M/H
Concord
2018 / 300 DSC
11-05-2016, 11:05 AM
That above for Youroo, to answer his question
Coachmen M/H
Concord
2018 / 300 DSC
