Old 12-22-2015, 03:48 AM   #1
BBBlue's Avatar
Lippert 6 point auto leveling system
I have a Lippert 6 point auto leveling system on my 2013 Sanibel 3500 and have noticed the front legs dropping 1-2" after traveling a while. I bring them back up and will at times still have a slight drop (approx 1") after traveling some more. I have had the unit going on three years and this issue just started this cold season. Any suggestions on what I need to be looking at?? Would the cold cause this slight movement?
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 12-22-2015, 04:38 AM   #2
Witch Doctor's Avatar
BBBlue, What is the outside temp when you noticed this problem, they have a warning about the system when operated below 30 degrees. I'll have to check and get back to you. That might be a cause. Is it only the front 2 or all or which of the 6 is doing it?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-22-2015, 05:12 AM   #3
BBBlue's Avatar
It is probably low to mid 30's and only the front two have done this.
BTCM(SW) Ret USN
2013 Sanibel 3500
Old 12-22-2015, 09:33 AM   #4
If it is in the low 30's then you will need to retract in the manual mode not AUTO mode. I would try that. These systems do not like the cold. You might also like to take a Qt. of hydraulic fluid out and add some Caterpillar fork oil. I think it's called spected or septic fork oil. Very good for cold weather use.
leveling
