Old 08-27-2014, 08:05 PM   #1
Great Horned Owl's Avatar
Lippert axle with EZ-lube wheel bearings?
I have a 2011 Palomino Puma 253-FBS. Their brochure specifies EZ-Lube wheel bearings. This surprised me because they use so many Lippert parts. I am getting ready to lube the bearings, and am getting very confused.
The Puma manual is useless. It doesn't even mention wheel bearings or axles. It has a Lippert manual with several pages on axles, but no mention of EZ-lube. I was not aware that an EZ-lube wheel bearing was possible on a Lippert axle
I climbed underneath, and verified that it is indeed a Lippert axle. Next, i checked that there is indeed a grease zerk behind the rubber plug in the center of the hub.
Can anybody relieve my confusion?
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-27-2014, 08:22 PM   #2
go online should be same as dexter axle, same principle.look up ez lube on heading.
stooge lover is offline   Reply With Quote
Old 09-16-2014, 05:21 PM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
I took off the center wheel cap to gat to the dust cover. Pumped a whole tube in to get a good steady flow of clean grease out.
donanddona is offline   Reply With Quote
Old 09-16-2014, 07:59 PM   #4
wbdavey's Avatar
Donanddonna - if you pumped a whole tube of grease into one hub, you've probably just covered your brakes with grease. I highly recommend checking the brakes! I believe Lippert has purchased Dexter so if you google "Dexter EZ Lube" you should get good info on this system.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 09-16-2014, 08:14 PM   #5
Crusadernoob's Avatar
That one's full!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 2
Crusadernoob is offline   Reply With Quote
Old 09-16-2014, 08:16 PM   #6
mud yapster's Avatar
Yep you better pull the tire and brake rotor and see where it all went. Bad idea to use more than a few pumps of grease.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-16-2014, 08:31 PM   #7
Ford Idaho's Avatar
I agree, Pull the drum, if you shot a whole tube in there you could have blown the seal and made a nasty mess.
Old 09-19-2014, 08:12 AM   #8
yep second post
Old 09-19-2014, 08:25 AM   #9
AquaMan's Avatar
As you can see, the grease is coming out the front (as it should), and many will pump the hub full and keep pumping until much or all of the old grease has come out the front, thus ensuring that only good new grease is in the hub. It's also not uncommon to pump half a tube into a new axle hub before seeing any grease come out the front. The rear seal is designed to withstand this pressure, but does sometimes fail. It's when the grease doesn't come out the front that there's problems. Lippert did purchase a division of Dexter, but I believe it was only their frame division, and the Dexter axle division is still independent of LIppert.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 09-19-2014, 09:09 AM   #10
Too much grease.
As a 30+ yr mech. Put plugs in those zirk fittings, you dont need all that grease.
martin73 is offline   Reply With Quote
axle, bearings, wheel
