The levelers, stabilizers all need to be applying about the same pressure. I also use pads underneath the feet to distribute the weight over the ground, gravel or pavement. If one leg is a little firmer down or up then parts of the rig can move slightly. It's important to get the rig as level as possible and not try to level corners up with the so called levelers as they will level that point, but has more pressure than the others.
Some people don't feel a thing while others can feel an ant moving under the pavement.
RV floors will flex and frames will flex some... just the nature of the beast. Your home probably has at least 3/4" laying on top of a floor joist... I doubt any RV is carrying that kind of floor.
Now if you have grandkids along 2,4 & 6 all bets are off and only an earthquake will be felt more.
Now we did stay in a Motorhome that had 6 point hydraulic auto levelers that could lift the wheels off the ground. That thing was solid.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
