Old 09-01-2009, 02:32 PM   #1
Lippert power tongue jack
My 08 V lite has the lippert power tongue jack, and 3 times now WE-(not naming names) have over-extended the limit of the length. The jack won't retract back on it's own when this happens, and you have to get the manual auxillary crank handle and open the flap on the top and hand-crank it down a little, so the worm gear catches hold. There should be a limit switch on this, so it won't allow it to go off the screw-shaft end. Just thought i'd let folks know about this problem, and how to fix it if this happens to you!!! HAPPY CAMPING!!! Randy
Old 09-01-2009, 08:04 PM   #2
dennisl24's Avatar
Stay away from anything Lippert makes. Had problem with electric step called them all they wanted was money and no help.
Dennis & Teresa
2009 Sunseeker 3100SS & KYMCO Grandvista
dennisl24 is offline   Reply With Quote
Old 09-01-2009, 08:55 PM   #3
milzat's Avatar
Does your jack look like this?
milzat is offline   Reply With Quote
Old 09-01-2009, 10:43 PM   #4
YES Mike, that's the one! I must use that hand crank if it gets opened beyond the limits of the worm gears. Randy
Old 09-02-2009, 10:36 PM   #5
AKA KE2DX
Don and Elaine's Avatar
Just ran across this post as today my power jack, the one pictured in the previous post, seized (not even 6 months old). I tried to manaully crank it but broke the handle! I had to put a Heavy duty bottle jack under the tounge and remove the power jack. Once out, I tipped it and water came gushing out of the top! Will call Forest River tomorrow and see what can be done...In the meantime, Thank god I had an old spare 3500lb crank style BAL jack and was able to put that on in place of the power jack.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
Old 09-03-2009, 04:45 AM   #6
Are all Lippert products imported? This is a new name to me.
Old 09-03-2009, 11:27 AM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
They're right in Goshen Indiana. They manufacture all the slide-out & leveler mechanisms for the Georgetown Motorhomes and a whole lot more.
http://www.lci1.com/
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-03-2009, 11:43 AM   #8
Ok, thanks for the reply..
Old 09-03-2009, 03:18 PM   #9
Hipshot's Avatar
Saw a Rockwood TT today, I didn't notice the model. They had a cover over the power jack. This looks like it may be a good idea to keep dirt and water out.
Hipshot is offline   Reply With Quote
Old 09-03-2009, 08:18 PM   #10
milzat's Avatar
The Lippert Tongue jack is manufactured and warrantied by Venture Mfg. Co..
I searched for information on Venture Tongue jacks and only came up with this and this.
Also found info on the Limit Switch Adjustment.
More info here.
Maybe contact Venture about your problem.
3636 Dayton Park Dr.
Dayton, OH 45414
Phone Number: (937) 233-8792 (937) 233-8792
Toll Free: (866) 365-1957 (866) 365-1957
Fax Number: (937) 233-8485
