Old 03-29-2016, 07:07 PM   #1
m2kamp's Avatar
Lippert Travel Trailer Shock Kit Installed
Hi All,
Just got done installing the Lippert Shock Kit (x2) on my Lippert I-Beam Frame today. Took me about 6 hours total over two days doing one side at a time.
We camped down at Galveston Beach last weekend and upon arriving the inside of the TT looked like it had been through an earthquake. No damage, just drawers opened and some things strewn about the floor.
Can't wait to see the difference on the next camping trip!
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 03-30-2016, 01:12 AM   #2
Fulltime family RVer
Good stuff. Be sure to come back and let us know how it goes once you get some miles on.
Old 03-30-2016, 05:59 AM   #3
Looks good. I'm doing the Joy Rider Kit and it states is for shocks to be effective they need be no angled no more than 40 degrees, which yours appears to be about 30 and mine will be also. Keep us in the loop on what your results are.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 03-30-2016, 07:25 AM   #4
m2kamp's Avatar
Hi Scotty, thanks! Yes, no less than 45 degress to be effective for lippert kit. I had to remount one shock as it was just below 45 degress. You will know that it won't work because the shock will not compress or extend (at least any appreciable amount) when cycling the suspension.
I will update after the next trip!
Old 03-30-2016, 01:14 PM   #5
Did you also replaced all your bushings with bronze and a wet bolt kit?
Plus, replacing the equalizer makes a HUGE difference. I just replaced my equalizer with a Lippert Equa-Flex and its great how well it rides now. I can't feel the driveline shock and flex from the weight while stopping and starting, plus the ride is way smoother. THe combination of shocks and a new equalizer would probably work great for you.
Major Malfunction is offline   Reply With Quote
Old 03-30-2016, 01:37 PM   #6
m2kamp's Avatar
Thats next on the list! Though if I'm happy with just the shocks, I will go with an HD wet bolt kit. I wouldn't put what came from the factory on a utility trailer- so cheap!
Old 03-30-2016, 01:40 PM   #7
For anyone that is not a believe in the factory plastic bushings, some of mine were worn through after only using my TT one summer. I have a 6500lb dual axle Coachman that I only bought last June. Just replaced the bushings last weekend and there were worn, mangled, and packed full of rust.
Such low quality for such an important component.
Old 03-30-2016, 04:02 PM   #8
I did the joy rider on my 5er and now I have a great ride
wire1946 is offline   Reply With Quote
Old 03-30-2016, 04:22 PM   #9
should the shackles also be upgraded given how the stock ones of so poor quality.
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
Old 03-30-2016, 08:09 PM   #10
Swift2
Swift 2's Avatar
We put the Lipper Shock kit on when we first got our new 320 home. Then off to 7000 Miles's plus another 1000 and haven't had anything come out on the floor. They really seem to work well.
Swift 2 is offline   Reply With Quote
led, trailer, travel, travel trailer
