Old 06-16-2012, 09:45 PM   #1
acadianbob's Avatar
Lubricating Manual Tongue Jack
Does anyone know of a way to lubricate a manual crank tongue jack? Mine appears to be totally sealed at the top; as in welded!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 06-16-2012, 09:57 PM   #2
sherdep's Avatar
can you post a picture of the tongue jack you have
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-17-2012, 10:43 AM   #3
acadianbob's Avatar
It's a 5,000 rated Bulldog. Doesn't look like it is meant to be able to be lubricated. Lubed for life?
Old 06-17-2012, 10:50 AM   #4
TURBS's Avatar
bull dog is not a factory jack .............. lol what happened to the original ??
to take those apart and lube can be done but i am not sure worth the effort .
I believe it requires screwing the jack completely out then taking the handle off and sliding unit out .
Old 06-17-2012, 05:03 PM   #5
acadianbob's Avatar
Factory jack was a piece of junk. 2,000 pounds rating and just about impossible to crank. The Bulldog was a whopping $30 and is a breeze to use. It's working fine but just thought that it might be wise to try to make sure it keeps on working fine. Lube seems like a good idea but I dont' think it is going to happen . . .
Old 06-17-2012, 08:37 PM   #6
sherdep's Avatar
Sorry for the laste response -
it has a 5 year warranty so if it fails you should be able to get it replaced.
looks like the top handle is bolted on and I am thinking you might be able to push grease down that hole.
Etrailer has a snip it on that jack here
How to Lubricate the Bulldog Top Wind Round A-Frame Jack # BD155032 | etrailer.com
