Old 06-07-2012, 08:25 AM   #1
lug nut torques for specific Forest River models
I just got off a site where another manufacturer had provided a video on proper torquing of lug nuts. They gave specific torque ranges for their model names, generally speaking-they gave one range for all and another range for a specific model, probally having larger lugs.
When I saw that video, I wondered why I could not find one for Forest River.
Most places I found on the subject said to refer to the axel maker's owner manual. Well, if you are like me, you dont remember seeing anything about lug nut torqes in any owners manual.
still-learnin is offline   Reply With Quote
Old 06-07-2012, 08:38 AM   #2
Experienced Newbie
My Apex 151RBX states 100# The lug nuts on my camper are 13/16".
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 06-07-2012, 08:46 AM   #3
What type of axles do you have? My last 2 Forest Products had the torque sequence and value in the axle manuals.
Len & Cheri is offline   Reply With Quote
Old 06-07-2012, 09:53 AM   #4
Triguy's Avatar
still-Learnin, your FR manual won't have it but the axle manual will have the information you need.
I see from your profile that you have a 2005 Wildcat 29rlbs (shameless plug to put that info into your signature line . Maybe someone with that unit can help verify the axle that you have).
You will find a number of manuals here in our downloads section (Files - Running Gear - Axles, Tires and Brakes.) These manuals will list the torque-sequence and proper ft-lbs for your unit.
ID which one you have (AL-KO, Dexter, Lippert, etc) and download that manual. Here is just one example of the info for torque -
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-07-2012, 01:54 PM   #5
ok, I am newby here. what do you suggest for signature line? my real name?
Old 06-07-2012, 01:56 PM   #6
dont know I do know that I have steel wheels with 6 lug nuts each and 15 inch tires
Old 06-07-2012, 02:01 PM   #7
Triguy's Avatar
Not at all, unless you want to. We encourage members to list information about their trailer and tow vehicle in their signatures as this helps to provide information for others to answer questions. You can do it in your User Control Panel (User CP).
Scott
2012 Shamrock 233S
Old 06-07-2012, 02:01 PM   #8
MtnGuy's Avatar
1st names are good (nicknames) I wouldn't use a last name.
Your trailer information (year, model).
Your tow vehicles would be good. (year, make, model, engine, final drive ratio)
Old 06-07-2012, 02:47 PM   #9
Triguy's Avatar
There should be information stamped onto the axles directly or a metal tag on each axle with the info.
But, in general, you could just assume 1/2" studs with a max torque of 120ft-lbs. Not that you have to go that high.
In general, unless otherwise specified by the wheel manufacturer, use a final torque of 85-95 ft/lbs.
This page comes from the generic Forest River Manual if you want to go by that.
Scott
2012 Shamrock 233S
Old 06-09-2012, 12:32 AM   #10
Too old to be too smart
SpringerPop's Avatar
Anybody else ever use LocTite (blue) on their lug nut threads?
For 1/2" lug bolts, I use 90 ft/lbs as a standard figure, and hit them afterward with some blue to "wick in" a few threads.
I use both a tap and die to "clean" both parts on removal, then repeat on installation.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
