Old 06-21-2013, 10:58 AM   #51
rotorhead1250's Avatar
Very interesting conversation on Torque and the art of torqueing.
1. a usually metal collar or neck chain worn by the ancient Gauls, Germans, and Britons
2. a turning or twisting force
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 06-21-2013, 06:57 PM   #52
Denver, CO
garbonz's Avatar
my torque wrench tops out at 120 and they were tighter than that. I got the unit in January, but I bought it off of the lot then, so it may and probably was sitting awhile before that.
None of this is making any sense to me. I am not inclined to mess with the stock situation till I change something for another reason, like tires or whatever.
2017 Fuse 23T
Old 06-21-2013, 07:31 PM   #53
Just a question, if your wrench tops out at 120 how do you know they were tighter? Reversing a ratchet type torque wrench and loosening a bolt/nut does not give you the initial tightening torque. Also, if it was sitting on a lot for several months, there is rust/corrosion to consider.
Old 06-21-2013, 07:59 PM   #54
Denver, CO
garbonz's Avatar
At past 120 nothing budged, no creaking, no movement, no nothing. Again, the question is what do I gain at this point disturbing the stock wheels and bolts? They are all above 85ftlbs. If I remove them now, I can't retorque them cause you say they are stretched and they have to be replaced. The wheels have not falled off yet.
I am guessing that FR tightened the crap out of these wheels. they weren't the right size in the first place (covered in an earlier post) and they had to get me a set of new load stickers.
2017 Fuse 23T
Old 06-21-2013, 08:18 PM   #55
Didn't say they were stretched, I am pretty sure wheel studs are gr 9, not gr 8 and a gr 9 bolt will take 141lb/ft. I would imagine the reason you couldn't move them is rust/corrosion, not from over torqueing. I would not replace them. A 1/2" wheel stud can be torqued to 90#-120#, that's why I set my wrench to 105# or 110#.
Remember, you can finger tighten a nut on a bolt and let it sit out in the weather a few weeks and you will have to use 2 wrenches to loosen it just because of rust/corrosion.
Old 06-21-2013, 08:37 PM   #56
Denver, CO
garbonz's Avatar
So should I mess with them or wait till I have a reason? What is the risk of a bolt or stud snapping given the stock situation here.
Per FR, I checked to see they were not loose by making sure that they were above 85ftlbs, so I fullfilled that bargain. When I do anything to the wheels, I will check and make sure they are torqued correctly.
what kind of lubricant do you use on these studs, prior to putting bolts back on?
2017 Fuse 23T
Old 06-21-2013, 08:44 PM   #57
DAISY BOYKIN's Avatar
I'm about torqued out!
You fellows are as bad as the weight police!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-21-2013, 08:44 PM   #58
Herk7769's Avatar
Just whatever grimy dirt is on my hands at the time.
I don't think they should be lubricated.
HAM CALLSIGN - KC3FFW
Old 06-21-2013, 08:48 PM   #59
X2.
Old 06-21-2013, 08:48 PM   #60
Go back to sleep!
