Old 06-20-2013, 11:42 AM   #21
Originally Posted by dustman_stx View Post
Wow. Guess we're just backwoods here because I've never seen any of the multiple tire shops in my area torque them.
And I thought Texas had the biggest and best of everything.
Old 06-20-2013, 11:59 AM   #22
Arefbee's Avatar
I had a friend once tell me he didn't need a torque wrench - he knew how much force it took to lift 75 lbs and would just apply that with a breaker bar. He eventually managed to ruin the engine of an AMX Javellin.
Personally I have broken a couple bolt heads when I should have used a torque wrench. I keep it with the rest of the sockets now. The price of the wrench is worth saving the inconvenience caused when things are done wrong.
Craftsman 3/8-in. Dr. Beam Style Torque Wrench, 0-75 ft. lbs. - Tools - Wrenches - All Open Stock Wrenches
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 06-20-2013, 12:18 PM   #23
How much problem does everyone have getting the plastic protective covers off of the lug nuts?
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 06-20-2013, 12:36 PM   #24
OK, How to remove the plastic caps on the lugs?
Yes, use a torque wrench and check before each long haul.
Now, the plastic caps on the lugs are a pain to remove.
Any ideas?
___________________________
2012 F-150 Ecoboost, SC
2013 Flagstaff 21FBRS
2010 Trailet New Yorker, 2-Horse
HorseyHauler is offline   Reply With Quote
Old 06-20-2013, 01:04 PM   #25
Herk7769's Avatar
What a PITA. Short of buying the correct tool, I use a pair of the free paint can openers available at Lowes or Home Depot.
Put one finger though the adult beverage opener loops, the lip of the lid tool opposite each other on either side of the plastic cover. Squeeze together and pull straight out.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-20-2013, 01:27 PM   #26
No problem, Phillips screwdriver, remove one screw on each wheel and off come the caps exposing the lug nuts. Take the caps off at home and leave them off the first day of travel so I can re-torque every 50-75 miles. Put them back on when we stop for the night.
Old 06-20-2013, 01:44 PM   #27
Herk7769's Avatar
I think he is referring to the kind that I have.
plastic "snap on" caps. (no screws)
Though mine are white.
Old 06-20-2013, 02:15 PM   #28
Denver, CO
garbonz's Avatar
ALL of mine are tightened at the limit of my wrench ( 120+) from the factory. I guess I should loosen them all and retighten? the forest river caution says tighten but nothing about loosen.
2017 Fuse 23T
Old 06-20-2013, 04:27 PM   #29
I'll bet we have a few in the garage. Thanks. I crimped a few using pliers and a piece of towel. They will probably fall of within a few years.
My son was enlisted Air Force LoadMaster on C-130 for four years, then college, ROTC, Flight School and was AC on KC-10. Now he is flying from the desert, chair-borne. He loved the C-130.
Old 06-20-2013, 04:31 PM   #30
Herk7769's Avatar
Torque must be "set" while turning. So if they were over torqued you will need to loosen them to re-tighten to spec.
Old 06-20-2013, 04:33 PM   #31
Herk7769's Avatar
Which unit? Schenectady or Niagara? If Niagara, I, or one of my students, might know him. PM me.
Old 06-20-2013, 05:40 PM   #32
Denver, CO
garbonz's Avatar
if they ain't broke, why fix em? I personally think I will wait till I change tires or something before I mess with them. I understand the theory tho.
My son helped me work on the brakes on my sailboat trailer several years ago, and while towing back to storage, I watched one of my wheels pass me on the the wrong side of the road. limped on to the storage lot and had to replace the drum AND wheel. Now I double check them.
2017 Fuse 23T
Old 06-20-2013, 05:54 PM   #33
Phat Phrog Physician
SabreDoc's Avatar
OK, so I'm studying that diagram from the FR Owner's Manual that Herk posted. I'm assuming that the torque "stages" it refers to are when you're putting the tire back on the hub. When checking torque on a tire already on the hub, I should just set my torque wrench to 85 ft-lbs and see if the lugs move, right?
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
SabreDoc is offline   Reply With Quote
Old 06-20-2013, 05:58 PM   #34
Please NOTE: If they have been over-torqued, they may have exceeded the proof strength of the bolt and theoretically should be replaced. Once the bolt has been stretched, it will not return to the original length or strength.
Old 06-20-2013, 06:13 PM   #35
Doc
The torque depends on the size of the bolt and whether the wheel is steel or aluminum. Attached is a chart for alum. wheels. I set torque wrench to 105lb/ft and make it click twice on each nut.
File Type: pdf Flagstaff TT Alum Wheel torque specs.pdf (311.4 KB, 59 views)
Old 06-20-2013, 06:20 PM   #36
Denver, CO
garbonz's Avatar
so now I have to replace all my bolts because FR overtorqued them... that will be an interesting warrantee claim...
2017 Fuse 23T
Old 06-20-2013, 06:45 PM   #37
Oklahoma Proud
MillerTime's Avatar
I doubt that the extra 1/8th of a turn to get from 85ftlb to 120 would stretch a bolt to the point of replacement. Besides the fact unless you just got it from the factory in the past month or so you may have a little corrosion or something else contributing to the extra feeling of over torque.
But good luck with the claim if you pursue it!
Old 06-20-2013, 06:49 PM   #38
Only if they agree they were over-torqued. A 1/2" fine thread gr 9 bolt(not gr8) will take 141 max on dry threads.
If your wrench will only go to 120lb/ft, I doubt if it is very accurate at that setting. You cannot verify the torque by loosening it. I don't know how you would go about proving they were over-torqued by the factory either.
Old 06-20-2013, 07:26 PM   #39
Originally Posted by MillerTime View Post
I doubt that the extra 1/8th of a turn to get from 85ftlb to 120 would stretch a bolt to the point of replacement...
1/8 turn could very well exceed proof strength, that's 45° which is a bunch.
Take any bolt and torque it to max torque for that type & size and then go another 45° and see what happens.
Old 06-20-2013, 07:59 PM   #40
Oklahoma Proud
MillerTime's Avatar
Oc- I believe your previous to last post contradicts what you just said and actually backed up what I said. What changed in the past couple minutes?
