Old 03-10-2015, 12:15 AM   #1
Lug nuts
Question, Of all the lug nuts that have tightned before a trip with your trailer. How many of the lug nuts were loose?
martin73 is offline   Reply With Quote
Old 03-10-2015, 07:38 AM   #2
5er_tom's Avatar
Just the one behind the steering wheel😃😃😃😃
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 03-10-2015, 07:40 AM   #3
5er_tom's Avatar
Actually, I have never found a loose lug nut even after several 1,000 miles.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 03-10-2015, 07:43 AM   #4
With alum wheels, once you remove/replace them, it usually takes 2-3 times of stopping after 50-75 miles and re-torqueing them for them to finally "seat".
Steel wheels seem to "seat" with one torqueing.
Old 03-10-2015, 07:55 AM   #5
geotex1's Avatar
X2 what OC said.
geotex1 is offline   Reply With Quote
Old 03-10-2015, 07:58 AM   #6
rattleNsmoke's Avatar
I've never found one loose even on aluminum rims, but I still re-torque because ya' know the one time that I don't....
rattleNsmoke is offline   Reply With Quote
Old 03-10-2015, 08:19 AM   #7
brookstone345sa's Avatar
I check truck and 5th every time out. I have found that if you remove a rim for service, check once or twice. You will find 1 or 2 of them have loosened up. If you drive a 4 WD truck they need to be checked also
brookstone345sa is online now   Reply With Quote
Old 03-10-2015, 08:29 AM   #8
I have found the opposite of oldcoot. The steel wheels on my popup would take a couple of times to seat but I have not found the ones on the TT (aluminum) wheels to be loose.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-10-2015, 08:50 AM   #9
PhoneDude 8289's Avatar
I'll re-torque before each trip. When I took delivery I checked the torque before pulling it off the dealers lot, 2 out of 20 lug nuts moved just a bit. Wouldn't call them loose but they did move, checked every couple of hundred miles after that and all was good. Put new tires on it and it took torquing three times for the lug nuts to seat, I still check torque on the RV and truck along with air pressure before each trip. TPMS on rv and truck
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 03-10-2015, 09:02 AM   #10
Old Ram Guy
Avenger61's Avatar
I can't recall ever finding one loose, but I have had a heck of a time getting them off. I think when they put them on with those pnuematic wrenches impact wrenches they jack up the air pressure and giggle a lot.
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
