Old 07-27-2016, 12:17 PM   #21
Witch Doctor's Avatar
Thank you Airdale, you are correct, the speed rating only has to do with the DOT testing. The Tireman9 has gone over this over and over. Besides Maxxis do not come with a speed rating. If it's a ST tire the max should be 65 MPH in my opinion, but I'm not buying people tires or paying for the damage. The old saying you can lead a horse to the water but you can't make it drink the juice..
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-27-2016, 12:19 PM   #22
Originally Posted by OldBob View Post
I agree. I set the cruise control for 62 mph and that's as fast as I tow. So far no one has hit me from behind and I've towed in just about every state.
+2
Originally Posted by WolfWhistle View Post
I've noticed the slower I go the more waves I get from folks passing me. DW wonders why they wave with a pronounced finger... told her they're telling me I'm number 1 in their book
WW
If one is driving between speed limit and 15 under speed limit in the far right lane, I'd say they can wave any number of fingers and I wouldn't care. If, however, one is driving at that speed in any lane other than the far right, "We're No. 1!" would probably be appropriate...
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 07-27-2016, 12:30 PM   #23
Iwannacamp's Avatar
FWIW I e-mailed Maxxis about the speed ratings. I will post what they say.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Old 07-27-2016, 01:57 PM   #24
Iwannacamp's Avatar
Here is Maxxis's answer...
To ensure your reply reaches the proper destination, do not modify or remove the subject line of this email. Chetty,
The Maxxis M8008 ST Radial is "Q" speed rated. However, according to the Tire and Rim Association, the U.S. tire industry specification authority, inflation pressures and load specifications in general for any ST Radial trailer tires, without a service description, regardless of the manufacturer, are designed and rated at 65 MPH. If the speed is higher than 65 MPH, the pressure and load need to be adjusted according to the following guidelines:
From 66 to 75 MPH the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) but requires no load adjustment.
From 76 to 85 MPH the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) and load should be reduced by 10%.
We hope this information is helpful. Thanks for your inquiry and interest in Maxxis Tires.
Best Regards,
Your Maxxis Support Team
Maxxis International USA
Email: MaxxisSupport@maxxis.com | Web: maxxis.com
2017 Puma 297RLSS
Old 07-27-2016, 02:24 PM   #25
Usually Confused Member
emm-dee's Avatar
Originally Posted by whatsupchuck View Post
I had to restart my computer as Internet Expl. got stupider!
I did check your recommended site and that gives me hope. Checking the Maxxis site, I guess they don't want it spread. This gives me hope along with good reviews by folks here who have Maxxis. Speed rating of 99 is way above what I need, but, good to know.
My present factory tires are the famous Castle Rock from the same supplier that blessed me with light rims / Lions Head. Contacting them several months ago, I could get no response on the pressure rating of the rims.
I am also glad to get the info. on price on the site you provided. Now I can ask Discount Tire why they want so much for the same tire. HMMMM!
I've posted this before. Didn't have any problem getting a response from Lions Head. Their wheels on my TT do not have a pressure rating stamp but do have a maximum weight stamp. Here's what LH has to say about that:
Here's the load ratings for Lions Head wheels:
BTW, we keep hearing about "China Bomb" problems but have there been any reports of problems with Lions Head wheels?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-27-2016, 03:33 PM   #26
Blog: RVroadtripper.com
hbillsmith's Avatar
Best Regards,
My 235/80R16 Maxxis 8008 are rated at a maximum pressure of 80psi and at that psi they are rated for 65mph. I interpret that to mean that increasing by 10psi to 90psi in order to run at 75mph would be a NO since that is above the Maxxis max psi for that tire.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
tire
