Old 06-07-2015, 06:56 AM   #21
Witch Doctor's Avatar
Originally Posted by Claude002 View Post
I hear what you are saying and your right for the tire----BUT---this discussing is not in relation to tires but mainly rims--some of us what to change to E type tire and we are not sure if the rims will take the 80 LBS as our RV came with D type that as to be inflated at 65PSI and after taking 1 wheel off to check the max inflation stamping, found it was not shownd.
Re=TST I got the 310 insted of the 307 because it can be used with the rubberSTEMS and got them directly form them at $250 delivered at the RV park 4 weeks ago pre-programmed, all you tell them is the amount of LBS you inflate your tires, I second guess the system also but beleive me its A 1 + no complaints
I went from factory "c" rated at 50 lbs. max to a "D" rated at 15 psi difference at CP and that is what I inflate them to per my GY Dealer. I have no problem at all. And also the PSI get's much higher then that from driving I have been to 79 PSI per the TST system, same rim. If the "E" rated tire your debating I wouldn't be worried about the rim. The tire dealer should be able to tell you that and if it will fit. I have never seen a rim explode. Not saying it can't happen but surely have not seen one yet. Has anybody?...
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-07-2015, 07:02 AM   #22
Claude002's Avatar
GLJURCZYK--Thanks for the update--appreciated a lot.
Claude002 is offline   Reply With Quote
Old 06-07-2015, 01:31 PM   #23
Owner/Operator
RodeoGeorge's Avatar
I have never seen a rim "explode", but I have had rims that leaked when the max rated pressure was exceeded.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 06-07-2015, 02:49 PM   #24
PhoneDude 8289's Avatar
I replaced the trailmasters with close to 3K miles on them with Maxxes 8008's E rated. I run them at 70 PSI, so far all is good.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-07-2015, 05:04 PM   #25
Claude002's Avatar
Rodeogeorge/phonedude8289-----thanks for the udate
