06-03-2015, 12:02 PM
Maxxis, thought I would share........
This was my response from Maxxis I received today.
Thank you for your request. Maxxis Internatonal is a top ten global tire manufacturer and I can assure you that we have all of the the required ISO Certifications and probaby exceed them by a tremendous amount. Our ST Trailer tires are built in our company owned state-of-the-art factory in Thailand.
Please refer to our load/inflation table in the trailer tire section of our web site and this should help answer your question about runing the tires at 70 psi.
Best regards,
Your Maxxis Support Team
Maxxis International – USA
06-03-2015, 12:08 PM
Always Learning
What was the question/request that you sent to them?
06-04-2015, 09:07 PM
06-04-2015, 11:05 PM
Blog: RVroadtripper.com
The inflation guide for their 16" E rated tires says 80psi
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
06-04-2015, 11:21 PM
Owner/Operator
That is IF the load on the tire is 3480 Lbs.
I doubt that you will be loading the tire to that weight.
You should inflate the the pressure indicated for you load.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
06-05-2015, 06:21 AM
It came from the factory with all 4 at 80psi. I can adjust at next CAT.
06-05-2015, 06:30 AM
I always run with my tires inflated to the max as stated on the sidewall of the tire, regardless of weight.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
06-05-2015, 06:57 AM
Why would you want to run at a lower pressure. Are you going to go to the scales ever time you go so you can make sure you are not overloaded? I am not sure what you are trying to gain by running them at 70 instead of 80.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
06-05-2015, 09:44 AM
Owner/Operator
Unless the rims are also rated for 80 PSI, you run the risk of having a rim fail.
Many people on the forum move up from factory tires to "better" tires. While they provide better failure avoidance, arbitrarily inflating to the pressure stated on the sidewall of the tire when the rims are not rated for that pressure is not recommended.
Also inflating tires to 80 psi on a trailer like a Signature UltraLite will result in a much harsher ride.
Hence my statement about inflating to the recommended tire pressure for a given load.
RodeoGeorge
06-05-2015, 11:08 AM
"Q: What are the consequences of inflating the tires to accommodate the actual loads?"
"A: If the inflation pressure corresponds to the actual tire load according to the tire manufacturer’s load and pressure table, the tire will be running at 100% of its rated load at that pressure. This practice may not provide sufficient safety margin. Any air pressure loss below the minimum required to carry the load can result in eventual tire failure."
Airdale
06-05-2015, 01:57 PM
Running the tires at max pressure can be good for many but if load is light you can actually reduce your contact patch of tire to the road. Rolling residents is good and load capacity good but it wears in the center and reduces the ability to stop. Less contact means longer stopping distance. Check wear pattern and see if you are wearing even or in the center.
06-05-2015, 01:58 PM
Have a Crusader 290RLT and want to upgrade the Tires--looking at the Carlisle ST225/75R15 they have 2 model --1 is LRD-8P # 5151401 to be inflated to 65 LBS--the other is LRE -10P#5151411 to be inflted to 80 LBS-- Both tires are for a 15 inch rim--if I choose the LRE I have to inflate to 80 LBS will my rim take it--today took 1 wheel off and nowhere do they state PSI rating --only the MAX load 2830LBS--since there is not much difference in pricing but want to be safer with a 10p instead of the
8p--can anyone tell me if the rim is strong enough for 80PSI--Thanks
06-05-2015, 02:16 PM
The rim manufacturer is probably the only one that can tell you what it is rated for, but
If the load capacity of the LR E tire at 65 psi is equal to or greater than the load capacity of the current tire (and of course if the trailer isn't over-loaded) then that is your other option - run the LR E at 65psi. This debate comes up all the time, and I've never seen anything near a consensus on what pressure to run when you change the tire to higher load rated tire - whether its on the tv or the tt. The vehicle manufacturer's sticker is based only on the OEM tire, and the max tire rating is based only on the max load capacity of the tire. You end up in no-man's land when you upgrade from the original load rating.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
06-05-2015, 02:25 PM
Your explanation is sound---Have 1 question--if i get the LRE 10P and its stamped max 80 PSI but put in 65 PSI will the tire be used up the same---or is the outside wear out faster---meaning if you over-inflate you will use up the center first--is it going to do the same if i only inflate to 65?
06-05-2015, 03:37 PM
Wish I knew, as I have tried to figure this out with my truck... In theory, if you put 80 psi in them, the center would wear more because they are over-inflated for the load. Whether that happens, I don't know.
Some tire manufacturers publish a load rating vs pressure curve. I would think if that was available, you would take the load rating of the OEM tire (since that is what the trailer, the axles, the rims, the brakes, etc are rated to carry) and find that load on the curve. Then you inflate your new, heavier tires to the pressure that corresponds to the original rated load.
But opinions and practices seem to be all over the map on this one, so I don't see a clear cut answer here when you go to a heavier tire than the OEM supplied.
06-05-2015, 03:50 PM
It should be stamped inside the rim, without removing the tire you will not see it. Here is Series 6 that Rockwood and Flagstaff use chart.
Coachmen M/H
Concord
2018 / 300 DSC
06-06-2015, 05:07 AM
I questioned them about being an ISO certification tire building company, not that means much, also the country of origin, like we didn't already know, and the ability to run a LR E tire at LR D pressure. I know so many people worry about the extra 15psi of air, my wheels do not have a psi. rating, just a max load rating according to them it appears to not be a problem. I believe I will try a LR E around 70-75 psi cold, we will see how that goes. Next step, scales. A LR E tire only has approx. 300lbs more load capacity than a LR D
My wheels are rated to 2830, the same as a LR E tire
06-06-2015, 07:43 AM
Do not know if this info will help anyone having to go thru this but here goes---last trip have bought the TST tire monitoring system--on our way back !st trip with the system---chech at the start tire cold at 65 PSI ---temperature outside for that trip was between 82/91 ---the temperature indicated by the system went up to 101degreF ON 3 OF THE TIRES and the pressure went up to 76PSI--ON 2 TIRES DIFF. SIDE--without any trouble---so in theory the Prime Time wheel with no PSI rating stamped ---and 2830 Max load rating stamp are PROBABLY BETTER THEN WE
THINK(hope i'm right) because i'm in the process of buying 4 LRE tires and will run them at 70-75 also.
06-06-2015, 03:49 PM
Tire talk
I use a digital infrared thermometer on all tires almost every time I stop along the road. It is my experience that, in all instances, the tires on the side of the vehicle that face the sun will always be 7 to 19 degrees warmer than the shaded tires. Also, in the middle of the day, with the sun overhead (depending on travel direction), temps are very close on all tires.
I am towing a 35' TT with a 163" wheelbase F-150, loaded near maximum weights, no one is going to convince me to not run maximum air pressure in all tires. I understand that pressures will build, but I believe the tire manufacturer has accounted for that.
A TST is next on my list of wants/needs and I will probably second guess it for a short while with my infrared thermometer. Just my $.02 worth.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
06-06-2015, 04:16 PM
I hear what you are saying and your right for the tire----BUT---this discussing is not in relation to tires but mainly rims--some of us what to change to E type tire and we are not sure if the rims will take the 80 LBS as our RV came with D type that as to be inflated at 65PSI and after taking 1 wheel off to check the max inflation stamping, found it was not shownd.
Re=TST I got the 310 insted of the 307 because it can be used with the rubberSTEMS and got them directly form them at $250 delivered at the RV park 4 weeks ago pre-programmed, all you tell them is the amount of LBS you inflate your tires, I second guess the system also but beleive me its A 1 + no complaints
