Old 10-13-2014, 10:35 AM   #1
Metal valve stems
Thought i made post earlier can not find..
Need part # for metal valve stem for 14" aluminum rims. Thanks can not find for some reason!!
Rockwood 2608WS
Paul
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 10-13-2014, 10:37 AM   #2
Think i put in wrong place!!??
Rockwood 2608WS
Paul
Old 10-13-2014, 10:40 AM   #3
offroad's Avatar
Depends on the rim, many can take the TR416 style.
My rims needed the TR428 style.
Moderator can move your thread for you.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 10-15-2014, 10:50 AM   #4
Looks like both of those can be used in a valve hole of .453"
and one of them includes two rubber grommets, so it could be used on a .625 valve hole.
One of the first things I ALWAYS do when I get a new trailer of any type is replace the rubber valve stems with all metal versions (like the links above) and then balance the tires.
BobandArlene is offline   Reply With Quote
Old 10-15-2014, 12:48 PM   #5
The actual hole size is not problem it is how the out side is cut to allow a washer. O think the T 428 is the one just wanted to find some one that has actually put thrm on the 14" aluminum rim that Rockwood uses.
Old 10-15-2014, 12:55 PM   #6
MtnGuy's Avatar
Done.
