Old 06-21-2016, 09:01 AM   #1
Monitoring Bearing Temps
We're leaving soon with our Salem Cruise Lite for Kentucky on one of the hottest days of the year. We just got a digital, temperature gun and wondering what are acceptable running temps and what I should be concerned about. We'll stop every 2 hours of so and I'll check the hubs. In the past, I've used the finger touch technique, but I'm going "high tech" now. Thanks
gfarmcafe is offline   Reply With Quote
Old 06-21-2016, 09:06 AM   #2
JustB_Rad's Avatar
I would say as long as they are all within a few degrees of each other you shouldn't have anything to worry about. If you have 3 that are 150 degrees and 1 that is at 175+ (Those numbers are just fictitious) you may have cause for concern.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 06-21-2016, 09:22 AM   #3
I check mine every time I stop for gas. Just this past weekend, with ambient temps in the low 90s, my TPMS system showed tire temps of about 92 degrees. Using a digital temp gauge, the brake drums measured 99-101 degrees as measured on the drum close to where the bearings are.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 06-21-2016, 09:29 AM   #4
rattleNsmoke's Avatar
Getting a true bearing temp may be tough because if you've adjusted your drum brakes shoes correctly they will drag slightly for several miles until seated. Magnets may also drag slightly creating parasitic heat.
rattleNsmoke is offline   Reply With Quote
