Old 04-07-2013, 12:07 PM   #11
Fire Instructor's Avatar
For those of us with the 14" wheels, our choices are very limited. After doing a lot of reading and asking lots of questions, I went with the Kumho's. Very happy with them thus far.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-07-2013, 02:18 PM   #12
prof_fate's Avatar
Is it worth going to 15" wheels? Found a place on line that sells wheels/tires complete - more money of course and shipping may be painful... just wondering?
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-07-2013, 02:26 PM   #13
PHS79's Avatar
IMO, not worth the money since you can get a good quality tire with enough load rating in 14". So by going to 15" you really wouldn't be gaining anything.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 04-07-2013, 03:04 PM   #14
I didn't have clearance between the wheels or between the wheel and the well to upsize to 15". The Kuhmo's gave the load range D and the speed rating that I was looking for.
Fire Instructor
Old 04-07-2013, 03:26 PM   #15
Take The Road Less Travld
MuddauberE's Avatar
I have the original radial trails on my trailer going on the 7th season and I don't have any noticeable dry rotting.When is the standard replacement cycle on trailer tires anyway? I don't put a whole lot of road time on my popup trailer and the tires still have plenty of tread on them. I figured by now I would be replacing due to dry rotting but these tires are still looking really good.
MuddauberE is offline   Reply With Quote
Old 04-17-2013, 09:54 AM   #16
FR28footer's Avatar
Smile
When we had our Grey wolf I upgraded to 15" and load range d Maxxis.One poster said it doesn't get you anything. I disagree. You get a bigger safety margin and a lot less stress while traveling.
You can't go wrong with Maxxis or Kuhmo.
Safe travels!
2012 Silverado 3500HD, 6.6L Duramax
Montana Big Sky 3625RE
Two Field Bred Springers
FR28footer is offline   Reply With Quote
Old 04-17-2013, 10:20 AM   #17
slide5r4fun's Avatar
14"
I just want tires that won't dry rot every 2 years as its inconvenient and expensive.
Although tire quality probably has a lot to do with dry rotting, using tire covers helps a lot with that also. We use our tire covers at all times, other than camping, seems to help tremendously.
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 04-17-2013, 10:26 AM   #18
sself1219's Avatar
I just installed a set of Westlake on my Surveyor ultra lite that weighs about 6500lbs loaded. My tire guy is also a trusted friend and said the Westlake are very similar to the Maxxis but about $150 less per set installed. So far i'm very happy with them and they were only $355 installed. My tire size is 205/75/R14. Load Range C.
Stephen
2004 Surveyor SV 261T
2011 Nissan Armada
sself1219 is offline   Reply With Quote
Old 04-17-2013, 11:08 AM   #19
Wanna Be Camper
SaskCampers's Avatar
It is recommended to replace trailer tires every 5 years regardless of miles or how they look.
John & Deb
2011 Flagstaff V-Lite 30WRLS
