Old 09-05-2014, 10:31 PM   #1
Need help with power tongue jack
I have a 2013 FR Sport 220 trailer. It came with a power tongue jack. I am not sure of the make and model. There was a paper label but it come off. It looks nearly identical to the LCI Lippert model with the LED light.
We have been out since April on a trip from upstate New York, across the US to Big Sur and up the west coast all the way to Alaska. We are in Yellowstone now on our way home. It's been an awesome trip.
The jack has, for the most part, been working OK. Every now and then when we are disconnecting or connecting, it stops working right in the middle of extending or retracting. Usually, I turn it off and on again and it comes back to life. That did raise a red flag but since it started up again and we are on the road, I didn't lose too much sleep about it. I've also twice noticed an electrical spark down near where the jack is bolted to the frame.
This morning the jack stopped working entirely. I checked the fuse and it was OK. I ended up manually cranking the jack and left the fuse out as a protective measure. Now this evening I reinstalled the fuse on a whim and sure enough, the jack functioned perfectly.
To me, the problem seems like a loose connection. But where? Before I disassemble the jack looking for a possible loose connection, I thought I'd ask if anyone else has had a similar problem or an idea as to what's going on.
Thanks in advance for your help.
Teddy
Forest River SP220 Sport
2013 Tundra 4.6L 4X4 Tow package
teddy is offline   Reply With Quote
Old 09-05-2014, 11:17 PM   #2
Batts-toy's Avatar
Sounds like the loose connection is at the bolts where the jack bolts to the frame of the TT hitch area. Possibly some cleaning is needed where the bolts are, I would (while TT is mounted on TV) unbolt the jack and thoroughly clean the area where the jack touches the TT hitch area so you get good metal to metal contact (on my TT this is the ground that completes the electrical circuit) then tighten the bolts up good.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 09-05-2014, 11:38 PM   #3
X2, If you saw a spark at the location where jack mounts to frame, I would agree that you have a poor ground. As suggested I would hook up to TV and then remove Jack and clean all the rust away so you have a good metal to metal contact between frame and jack mounting flange.
When I install my electric Jack I installed star washers between the bolt heads and jack base. I also installed star washers between the nuts and frame.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 09-06-2014, 10:58 AM   #4
Thanks. I will check the ground connection.
Sent from my VS910 4G using Tapatalk 2
Teddy
power
