06-07-2015, 05:41 PM
Need new tire and TPMS recommendations please
I posted this in the Wildwood forum, but I think this is probably a better spot.
My '04 Wildwood needs new tires, and I have no idea what to buy. The trailer's plate says 5200lbs, GVWR 7515lbs. I've tried to Google and get a good answer, but so far all I really "know" is I need LT or ST (and if I'm reading correctly, LT's start at 16"?)
The tires (probably factory, I doubt the previous owners replaced them, and I've owned it since Summer '09) on it right now are 205/75/15. Can I change the tire size??? (Say 225/75? I know I have to stay with 15...and if I can, should I?)
Sam's is usually my go-to tire place, as we move a lot. They have ST205/75R15 Goodyear Marathon Radial - Sam's Club. I'm not exactly sure how to calculate the weight rating? Do I multiply it by four, since my TT has 4 wheels? If so, I think I might need different tires? It says 1820 at 50lbs pressure, which would be 7280 if I multiply by 4....am I trying to hit that 7515 and have a cushion? We do tend to travel heavy. Our next trip will be 1700 miles and we will definitely be loaded down, as we're moving cross country.
Thanks for any advice!!! (If those tires don't fit the bill, could anyone recommend some that would, and possibly a place to get them installed? We're in Colorado Springs, CO right now)
Also, can someone recommend a decent, preferably cheap, TPMS for the TT? My TV has one from the manufacturer.
Me, Him, a bunch of kids and cats, one loud-mouthed parrot, and one spoiled rotten Shih Poo
2009 Chevy 2500HD 4x4 Crew Cab
2014 33' SOB TT
06-07-2015, 05:49 PM
Wondering if Goodyear Wrangler HT - LT215/75R15D 106Q - Sam's Club would fit/be a better choice? Would REALLY prefer to stay with Sam's, but I will go elsewhere if I have to. Being military, we move a lot, but we've never not had a Sam's within an hour, which is handy for tire repair/replacement when needed!
2014 33' SOB TT
06-07-2015, 05:50 PM
I would go with the 225-70 or 75 x 15 LR D Goodyear Marathons with all metal stems, balanced with TST TPMS 507 Flow thru sensors installed.
06-10-2015, 02:29 AM
Hi Old Coot, I've read that the Marathons aren't any good anymore? (Made in China?) I got the impression I should avoid them, but the posts I was reading were from 2012 and 2013, do you know if the tires are better now?
Would it be safe to assume I would need to change my rims to switch to 225s? (Sorry I know next to nothing about tires!)
I went and measured my rims tonight, they are 5 lug, 2-5/8" between them, the tires are Carlisle Radial Trail, ST205/75/15. Any chance someone knows what pressure they should be inflated to? (They all look low, but I didn't check the pressure today.)
2014 33' SOB TT
06-10-2015, 12:35 PM
On my last trailer I originally had Maxxis tires. I forget the size but I think they were 225/75/15 load rating D. I replaced them with the same. The reason I replaced them is age. They were 7 years old. Maxxis makes some nice tires. I never had one issue with them. They only make the one trailer tire. It's ST8008. Jerry
2005 GMC Sierra 2500HD, Duramax CC/SB
2022 Rockwood 2613 BS
06-10-2015, 12:39 PM
As for the TPMS, TST makes a good one. Check Amazon. EEZTire has a 4 sensor system for $269 also on Amazon. My buddy just bought it but has not used it yet. It also has good reviews. Jerry
06-10-2015, 12:43 PM
Maxxis with metal stems and TST 507 here.
2014 Brookstone 340LS
2015 Ford F350 CC/LB King Ranch 4x4 Diesel DRW
06-10-2015, 12:45 PM
Michelin LT is my choice. Change at 7 years
06-10-2015, 07:09 PM
you are on the right track sams a nd tpms, Michelin is good choice ,I hear goodyear marathons are now made in china??? hopefully to goodyear specs .iuse great rv products tpms sams wouldn't install all metal valve stems,because they didn't sell them.
06-11-2015, 05:16 AM
China tires are not the problems
I read that you have issues with Goodyear tires since they are made in china! Well being made in china should not be your issue as most are today, the issues are much more involved then being made in china and here is a link to the tireman how should be able to shed some real info into your tire needs.
The issue with china bombs have been around for some time but as you will see after watching some of his videos it was not the country of origin that is the main reasons for tires on rv's to go bad. The main reasons are weight, pressure, and age. Yes there are other things your should know but these are the main ones. So take a watch at some of the videos and then make your choices.
Oh and by the way Goodyear marathons are great rv tires but as you said watch your weights!
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
06-16-2015, 09:18 AM
I keep seeing threads about China Bombs and upgrading from a C to a D or E load range? Question I have is do you have to be concerned with is this, my tt has a sticker with vitals in it that has tire inflation at 50 lbs. I googled the Duro 225/75 tires and the 50 lbs is what is stated for the tire. The class D tire states that 65 lbs is the right lbs and 90 for the class E. I am guess if you upgrade you run the the inflation rate, if so is there a concern of the wheel handling the new rate, especially the E which is almost double the C? How do you tell the pressure capacity of the wheels? I do like the extra carrying weight, but then again is there a issue with axles capacity? Will sneak up on some scales some day, have been comfortable with the 1600 cargo capacity of the Flagstaff. Do not carry much water in tanks, fresh or waste, kinda foolish I think to haul water and its weight. Thanks for the reply?
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
