Go to a local store and work with them (Tractor Supply/local Tire store, RV parts store, ect) and get a rim (does not have to match your 'regular rims) and spare tire (that is the same size and go up one range size) ie. I changed all of my tires from a D range to an E range. If you have any 'issues', it is better to handle it local than e-bay. you may 'think' that you 'saved' a few dollars from 'e-bay-, but in the long run... you will not. Put a High Pressure or steel valve stem on the rim. Some tire places do not have the steel valve stems, but all seem to have High Pressure stems.
Brother Les
