03-14-2017, 07:15 AM
#21
He arrived at the house about 8:30 and departed by 2:30.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
03-14-2017, 08:12 AM
#22
Here is his answer. Note, I have the Joy Rider System with shocks installed.
This video was done in Oct. 2015. At that time we were saying what Titan was telling us. The caliper should be the same direction.
In November 2015 Dexter Axle bought Titan Brake Systems and has been integrated into the Dexter family.
About a year ago I had a discussion with Dexter engineers about this because on some axles the bracket can only be mounted in one direction that forces the calipers to be mounted in opposite directions. There are other trailers like the Landmarks that come with shock absorbers and the shock mounts interfere with mounting the calipers the same direction. Dexter says it makes no difference in the direction the caliper is mounted.
In fact the new Landmarks that have original equipment Dexter disc brakes are mounted in opposite directions because of the shock mounts.
Titan’s old documentation is being updated by Dexter and this is one of several changes they are making.
FROG AR-0019-242
03-16-2017, 08:04 AM
#23
All I can say is WOW! What an impressive increase in braking performance with the new disk brakes. Yes, the drum brakes did stop the 5th wheel but I always had the feeling I was on the edge of their capacity. With the disks braking is positive and they have a very solid feel and they give the confidence that stopping the 5er is not taxing them at all. I strongly recommend them.
Tom & Renée
Durham, NC
03-16-2017, 08:56 AM
#24
I called the man and he told they would be back in NC in May. I have to call him back and set up a appointment. This is probably going to be my last camper, I like the 36CKTS but DW wants to keep the camper and truck that we have now. But the disc brakes seem the way to go. The price is not cheap but I know I can not install the brakes.
03-26-2017, 01:10 PM
#25
Ordered the disc brakes, appointment is 5 or 6 April. First trip after that is 7 April.
03-26-2017, 01:59 PM
#26
Left Coast
Make sure you buy a spray bottle of wheel cleaner......
03-26-2017, 02:46 PM
#27
Spock123,
Good for you. You will never regret it.
Tom & Renée
Durham, NC
03-30-2017, 02:16 PM
#28
The installer is supposed to be here Wednesday morning. I'm going on a little 3 day trip two days later. I get to try the brakes out going through Wilmington NC.
03-31-2017, 09:19 AM
#29
I ordered all the components to install Kodiak disk hubs on the Silverback 29RE along with the BrakeRight EHB actuator and a steel tubing kit. Ordered from Eastern Marine who had the best prices. Total cost for everything was just a tad over $1300. Supposed to arrive today. Looking forward to getting started. The only part of the install that will be challenging is routing the tubing, but I'm looking forward to it. Should be fun.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
03-31-2017, 09:23 AM
#30
Left Coast
What axles?
03-31-2017, 09:25 AM
#31
Dexter 6000 lb axles
03-31-2017, 09:28 AM
#32
Left Coast
04-02-2017, 12:18 PM
#33
On my CC I installed the calipers (all to the rear). This may be why I ended up making a trip to the auto parts store to pick up a couple short pieces of tubing. I was contemplating adding shocks but it sounds like the calipers may not allow this....hum.
I have yet to hear regrets from someone who added disc brakes.
Doug & Cindy
2014 36 CKTS: Titan Disc Brakes, EMS, Trav'lr, 20k GooseBox
2016 Ram 3500 CTD 4x4 CCLB DRW, Laramie, Factory Rear Air Suspension, 3.73
04-02-2017, 12:26 PM
#34
Originally Posted by aceinspp
Will these work on Torflex axles? and do the same wheels still fit? Later RJD
The wheels will bolt right up and be in the same position they were when bolted to the drum brake hub.
Contact Ron at Performance trailer brakes to get an answer to the torflex axle question. My guess is that that will.
Doug & Cindy
04-02-2017, 01:00 PM
#35
Georgia Rally Coordinator
Thanks will try to contact them and see if its doable. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-08-2017, 01:24 PM
#36
I contacted Ron and he said they do Torflex axles also. Waiting on replay for price and time. Later RJD
Days camped 2019 62
04-15-2017, 06:25 PM
#37
Well its been a week and no return call as they where not sure about the fit. said they would have to check with the manufacture of the axles. Later RJD
Days camped 2019 62
04-15-2017, 06:28 PM
#38
Left Coast
Why wouldn't they fit?....If bolt pattern the same as caliper bracket, and uses same bearings...
04-15-2017, 06:30 PM
#39
He said he would have to check with the folks that make the axle as they had no listing for 4000# axles. Later RJD
Days camped 2019 62
04-15-2017, 06:33 PM
#40
Left Coast
3500 lb axles is what I saw.....Mine are listed as 4000.....So I pulled a drum and checked numbers of bearings and backing plate bolt circle
Numbers all good to be able to make swap
