Old 08-02-2013, 11:38 AM   #1
Road-King's Avatar
New Tires advice Class D vs E
Fixn to order new TT tires. 225/75R15 class C came on the TT. TT's GVWR is 8819. At least looking at going with GYM Class D's. Few bucks more I can go with class E's. I know there are opinions out there...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-02-2013, 12:28 PM   #2
avolnek's Avatar
IMHO I feel that anything to do with trailers or tow vehicles you should be trying to get the HIGHEST load rating you can from a tire to fit your wheel.
Needless to say I'd vote for spending the little bit extra now to possibly prevent a blow or and needing to replace a blow tire, or worse wreck truck or trailer!
No sense skimping when you are already buying them...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-02-2013, 12:49 PM   #3
Fulltime family RVer
If you go up to E-range tires, make sure your wheels can go up to 80psi.
ependydad is online now   Reply With Quote
Old 08-02-2013, 03:10 PM   #4
Road-King's Avatar
60 psi.... Looks like class D's would be the ones, without changing rims too.
Russ & Kim
2014 Alpine 3600RS
Old 08-02-2013, 03:52 PM   #5
During my research on tires, I read a good article about st and lt tires. The interesting part is what the guy called reserve. The e rated tires would just have more reserve than the d rated tire. I'd go with the e if money wasn't an issue.
Frankm2 is offline   Reply With Quote
Old 08-02-2013, 03:59 PM   #6
Road-King's Avatar
Go with the E's and run them at 60 psi?
Russ & Kim
2014 Alpine 3600RS
Old 08-02-2013, 05:55 PM   #7
Yea, or if you took it to a scale after you have it geared and know the weight, there are charts on the Internet which would tell you the correct air pressure, which should be at or below 60 psi.
Old 08-02-2013, 06:16 PM   #8
Senior Moment
rockport's Avatar
Switched my trail express LR C tires out for Maxxis LR E tires and run them at 70psi cold. I have aluminum rims supplied to forest river by lionshead, I called them about the higher psi, they said just make sure you change the valve stems, I went with the stainless steel.
rockport is offline   Reply With Quote
Old 08-02-2013, 10:23 PM   #9
Road-King's Avatar
That's interesting, that's the rims I have and their web site says 60 psi for the load on 15 inch rims...
Russ & Kim
2014 Alpine 3600RS
Old 08-02-2013, 10:45 PM   #10
Senior Moment
rockport's Avatar
You wouldn't happen to have a link to that website would you. I couldn't find one.
