Old 05-23-2012, 08:41 PM   #11
$259 with 4 sensors
http://shop.tsttruck.com/product.sc?...1&productId=26
Old 06-09-2012, 02:34 PM   #12
On our trip today with our new TST 507 sensors, the alarm went off on 2 sensors due to the high pressure. I had set the pressure limit to 69 psi. Scared the daylights out of me and DW. Don't really know what it should be set at but will try 75 psi and see what happens. Temp went from 60 to 98.
Old 06-09-2012, 03:31 PM   #13
fonzie's Avatar
My TST 507 TPMS high pressure is set at 60 psi for 50 psi cold inflation and so far so good. Highest pressure tires got to was 59 psi and it was about 85 degrees F ambient temperature. On hotter days I might have to increase to 65 psi for the alarm......
Fonzie
Old 06-09-2012, 03:36 PM   #14
bob213's Avatar
I thought recommended settings were 20% above and 10% below actual psi? My new 507 with flow thru sensors should be here next week. Can't wait for a new toy!
bob213 is offline   Reply With Quote
Old 06-11-2012, 01:55 PM   #15
Too old to be too smart
SpringerPop's Avatar
After setting mine for 50 psi, I could set the low at 45, but the high did not have 60 available.
Just 59 and 61. I set it at 61.
First road test this Thursday afternoon. About a 100-mile trek in the Mojave Desert.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-11-2012, 02:12 PM   #16
bob213's Avatar
Originally Posted by MilCop4523 View Post
cost of sensors and receiver?
Right now you can get the flow thru sensors for $259. or call them and ask them to match the price at GreatRV.$239. for four sensor 507 kit.w/shipping.
Old 06-11-2012, 02:56 PM   #17
I have 507 set and the only complaint i have, while driving, it will occasionally lose the signal from one or two of the sensors. It's a real pain in the butt.
2018 267 RBSS
2009 Expedition Eddie Bauer 5.4L
Nights camped in 2017 - 80
Nights camped in 2018 - 3
18267RBSS is offline   Reply With Quote
Old 06-11-2012, 04:24 PM   #18
Is it possible the battery is bad in that sensor? Have you contacted TST and informed them of the problem? They have been super resposive to me. I can pm an email address if you want.
Old 06-11-2012, 06:41 PM   #19
Dunnnc, I also found them very helpful, I never called about this problem. I thought it might be battery related, but then I read that when the battery is weak, it will flash a crossed out battery pic on the monitor when that sensor comes up. Also, it wasn't just one, at times it was two or three....
2018 267 RBSS
Old 06-11-2012, 06:45 PM   #20
bob213's Avatar
I think they have a signal repeater antenna. Is that an option or does it come with the kit?
