03-21-2015, 08:03 PM
#21
Originally Posted by HIDE OUT
Thanks for to much info This is what I found out. My current tires Good year wranglers P275/65 /R18 have max load 2601. The tires I am looking at Cooper A/T3 C's have a max load of 2335. E's max load is 3415. So if I am thinking right my current P tires 4ply hold more then cooper C tires 6 ply. So if I want to get rid of the squirmy swaying problem I have to move up to E range no??. Or I just keep my current tires ???
P tires on a towing vehicle are a significant contributor to sway. A LR D or LR E would eliminate the tv squirm.
03-21-2015, 08:09 PM
#22
X2
B and B
03-21-2015, 10:22 PM
#23
member
Originally Posted by B and B
X2
They don't have a D tire in my size and brand so they recommended a p- metric tire with a load index 116 that is comparable to a D the LT C has a load index 113 and the LT E has a index of 123. The only difference is the C is 6 ply and the E is ten ply. And I think the p-metric is 4 ply. Is it the ply that reduces the sway or the load???
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
03-21-2015, 10:25 PM
#24
member
I put E on my truck as well, i don't drop the pressure and the ride is a bit rougher but after all it is a truck! The tires cut through the snow better with a little more Nitrogen.
B and B what psi do you run? And are they the factory rims
03-22-2015, 03:02 AM
#25
I run the exact same size tire on my Tundra. My trailer weights loaded are about the same as your unloaded weights are. I normally run the P rated (LTX M/S2) tire, and I probably wouldn't want to tow anything more than that on the P rated for sure, but have a 10 ply tire on currently (winter tires - Nokian) and the squirm/sway is virtually non existant, however I do dislike the unloaded ride with the 10 ply's, even with the reduced pressures (50 psi unloaded, any lower and they were getting really warm on the highway)
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
03-22-2015, 04:33 AM
#26
Just a member
If so, why do auto manufacturers market SUVs and light trucks, that specify significant tow capacities, come equipped with P-Metric tires? They're being negligent? The consumer is not being made aware by the vehicle manufacturer of the hazards associated with towing with a P-Metric tire? I don't get it. If the aforementioned tires are causal to hazardous towing conditions (sway), why the heck are they being fitted to potential tow vehicles.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
03-22-2015, 05:09 AM
#27
Because people want their rig to ride like a caddy LT tires are not conductive to caddy like rides.
I will also guess that the same size LT tire is more spendy.
It could be that a large majority of SUV owners are in for the show not the tow.
03-22-2015, 05:41 AM
#28
Just a member
Yep, I get that. Cadillac ride is cool. However, where in this equation does the dealer/seller present the buyer with the prospect of hazardous miles ahead (trailer sway) should he/she be inclined to hitch up a TT with the OEM P-Meric tires that are installed on this vehicle?
03-22-2015, 05:51 AM
#29
I have seen Lots of (Trucks?) with what they refer to as (24s),what I call (O-Ring) tires Pulling (Trailers?)! They are Trucks with Hitches but they Don't fall into the Factory Class of (If Properly Equipped)!! Some trucks are for Show and some trucks are for TOW! Youroo!!
03-22-2015, 06:03 AM
#30
The P tire will tow but not under the best of circumstances (caveat emptor).
It's like the RV dealer that tells you your 1/2 ton PU will tow a 16,000 lb FW, yes it will but it is gonna be a short ride.
So as long as the tires meet the minimum safe towing standards no mention be made about LT's.
03-22-2015, 07:40 AM
#31
The overwhelming majority of SUVs are never used for towing and the mfgrs cater to the majority. The P tires will carry the loads, but with the more flexible sidewalls they will exhibit "squirm" with the load. I have tried the P tires (GY Fortera) on my truck and I can tell you they will hold the load and I didn't get any noticeable squirm with 44# of air in them, but they did wear out much, much faster (Less than 30k and worn bad). Went to LR E and after 30k, they still look like new.
I would not tow on any P tire.
03-22-2015, 07:57 AM
#32
member
I run the PSI listed on the sidewall of the Coopers towing or not because there is nothing on the tire that says to do other wise.
Underinflated tires is one of the main reasons tires fail I will not run the risk of wrecking a 160 dollar tire or my truck by underinflating it.
Run the pressure on the sidewall of the tire, it IS the safe thing to do.
So do you run 80 psi all the time
03-22-2015, 08:05 AM
#33
On my LR E's I run 65#F/R loaded and 35#F, 30# R unloaded. Over 30K on tires and they look like new, but most of the mileage has been loaded pulling the 5er.
03-22-2015, 08:17 AM
#34
I agree. It is not totally a load carrying capacity situation. It is also about side wall stiffness and controlling "movement".
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
03-22-2015, 08:22 AM
#35
Yes I do.
Discount tire has done a great job of keeping the tires aired and rotated.
Yes it does ride like a truck, but I do not mind.
I am ready to hook and go with no time out to air the tires up.
03-23-2015, 01:26 AM
#36
A lot of people get bad information about their truck tires load capacity (even from tire dealers).
Passenger tires - any kind or design - MUST have their load capacity de-rated for use on Light Trucks. So your figure of 2601# for your OE tires is really 2364#. Vehicle manufacturers will automatically apply the reduction when fitting OE tires on the truck. The standard reduction is the value of the tire’s maximum load capacity found on the sidewall divided by 1.1.
ST & LT tires use the Load Range lettering system to figure tire load capacities. Passenger tires use the load index numbering system to figure tire load capacities. The two systems are not compatible.
Airdale
p.s. Your replacement tires should have the capability to carry the load established with the OE tires (2364#).
03-23-2015, 03:30 AM
#37
Just a member
I get that - soccer moms appreciate that plush ride in the two and a half ton big iron thing. However, said vehicle, equipped with P-Metric tires, is specified by the manufacturer as being capable of towing an X thousand lb tt. Based on the frequent refrain in this forum that P designated tires contribute to trailer sway, it would be safe to assume that the vehicle manufacturer is potentially... negligent?
I appreciate and respect that. My experience differs.
03-23-2015, 03:51 AM
#38
Just a member
So... is the dealer/seller obligated to inform me that the light truck's tire load capacity is not what is molded into the sidewall of the tire?
03-23-2015, 04:25 AM
#39
Airdale
And I would be that tire dealer. You are absolutely correct and I knew that but totally forgot it when posting. Thanks for posting the correct information.
I went back and edited my original post to reflect this for future.
2011 Flagstaff 831 RLBSS
03-23-2015, 05:12 AM
#40
Hello, I have 20 inch wheels and run 65 psi. Based upon loading this is plenty with Nitrogen fill.
B and B
