Old 09-16-2014, 12:41 PM   #1
Newbie with stabilizer jack problem
I'm new to the forum but I have been a reader for about one year. My problem is that stab. Jacks won't work. I searched for the fuse under the a-frame and also inside the trailer but can't find it. also I checked the electrical panel. It's like no power to them. Totally dead. 2012 flagstaff 30wrkss.
52413 is offline   Reply With Quote
Old 09-16-2014, 12:50 PM   #2
TURBS's Avatar
Have you checked power before the switch then again after?
power at the stabilizers?
The circuit breaker may be behind a Frame up under frame.
If you have an enclosed under body then there should be an access plate.
Welcome to the forum!
TURBS
How can I annoy OC today?
Old 09-16-2014, 01:19 PM   #3
I had same type of problem on my Rockwood 2608 when I bougt in Feb. the fuse kept blowing in the fuse panel and found a loose wire in the circuit breaker causing the problem the breaker was behind a panel in the storage compartment directly above the stabelizer on the right side ( right side being the passenger side of Tv)
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 09-16-2014, 01:32 PM   #4
Kaadk's Avatar
Mine have one of those resetable current limiters instead of a fuse. Try looking for a little box with 2 posts. Then check on the side of it for a button. They're hidden behind false panels in the storage areas near where my switches are.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 09-16-2014, 01:36 PM   #5
I didn't check power to the stab motor yet. I thought since both front and rear will not work had to be fuse power on same line. I found only one fuse in A frame. It goes to power jack.
Old 09-16-2014, 02:00 PM   #6
Look in the main fuse panel see if you have a led lit if so that is probably the fuse to the breakers that are resettable for the stabelizers at least that is how mine is. the resettable on mine did not trip it was the fuse in the panel that tripped because the wire was loose and causing an over load because of the connection. After tightening the wire I have not had a failure on mine.
Old 09-16-2014, 03:12 PM   #7
So far no luck. Nothing under a frame. Pulled panels under TV main wire bundle goes though there but no fuses. Have not checked behind cb panel yet. The temps upper 80 s ac running. Thanks for tips so far.
Old 09-16-2014, 03:25 PM   #8
Fuse will look similar to this
You may have to take a panel out to see it
Old 09-16-2014, 05:08 PM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
Big Paul, I think the picture is a fuse release relay. Forest River didn't install any of these in my RV. Instead they used inline blade fuses. Tracing wires is a bit of a pain. My local repair shop found mine close to the exterior switch and the elect. motor. He said he had to remove a panel. (he said). Have you checked to see if their is power to the switch (12volt light tester)? On the other hand in the interim I used a cordless drill with a short extension and a modified deep well socket cut on the end of the socket to fit the dowel pin in the end of the screw rod of the stabilizer. The manual screw jack that came with your RV should give you a guide.
donanddona is offline   Reply With Quote
Old 09-16-2014, 05:30 PM   #10
[QUOTE=donanddona;702556]Big Paul, I think the picture is a fuse release relay. Forest River didn't install any of these in my RV.
This picture is not exact to mine reason I said looks similar, to mine seems even if it says it is a Forest River most are different was just a thought since it is what happen on my unit. But it does appear that same type problems on most units weather Rockwood or other models just have chase the wire out until problem is found.
newbie
