Old 05-02-2013, 12:16 PM   #21
Senior Moment
rockport's Avatar
Originally Posted by whj77372 View Post
Am I missing something, my D rated tires run with 65 psi?
No D rated is 65. My C rated are max 50 psi.
rockport is offline   Reply With Quote
Old 05-02-2013, 12:22 PM   #22
Don't understand, No D rated is 65, are you implying that D rated is not 65?
Old 05-02-2013, 12:35 PM   #23
One of the main reasons for using nitro is that it is not affected by temperature change. This is why it is used in racing tires. All the research I have done says it won't hurt but don't waste your money. If pressure drops you can simply add compressed air. I used nitro when I was a refrigeration mechanic to leak test because it was not affected by temperature, and a drop in pressure meant a leak in the system, not simply a drop in temperature.
jacknel is offline   Reply With Quote
Old 05-02-2013, 12:35 PM   #24
Senior Moment
rockport's Avatar
Saying d is 65, c is 50 and e is 80.
Old 05-02-2013, 12:55 PM   #25
B47
Originally Posted by F and E Damp View Post
The only tires that NEED nitrogen are those on jet airplanes. When I was at Boeing, I researched landing gear tire bursts. In the early 1960s there were several accidents that resulted from in-flight bursts of retracted tires, one with 70 fatalities.
The research showed that, if an airplane took off after taxying a long way with a dragging brake, there was a risk of either an over-pressure burst or a tire explosion in the first hour of the flight. We had a 727 case where the tire exploded from gases being released from the rubber compound and then spontaneous combustion. Analysis of the failed tire bead steel cords indicated a pressure of about 12,000 psi!
If your rig can do 150 mph for a couple of miles (with a dragging brake) and then retract the wheels, by all means spend the extra.
The landing gear tire bursts were not the only reason. The FAA issued Airworthiness Directive 87-08-09 requiring nitrogen to be used to prevent explosions resulting from overheated brakes and the subsequent explosions.
Old 05-02-2013, 12:59 PM   #26
semi-senior member
denandra2's Avatar
you mean no one else changes their air from summer to winter? just BURST my bubble!!!!!!!!
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 05-02-2013, 01:00 PM   #27
B47
Sorry
Old 05-02-2013, 01:19 PM   #28
Denver, CO
garbonz's Avatar
Originally Posted by kb4srn View Post
I'll let them down to 50 psi tomorrow. Meanwhile, Old Coot, I'll make sure not to jar them. Thanks for the advice.
Collect the air in a bag and then hook it up to your compressor inlet when you fill again, and you can recycle it. I wish they would use helium so that our rigs were lighter. Or maybe nitrous oxide so we could laugh while we fill.
LOL
I LET 5psi out of mine and felt a little guilty.
2017 Fuse 23T
Old 05-02-2013, 01:23 PM   #29
Senior Moment
rockport's Avatar
I was surprised with the pressure change while driving, went from 50psi cold at start of trip, up to 60-61 psi after driving for a couple of hours. This was according to my TST tpms system..
Old 05-02-2013, 02:37 PM   #30
Denver, CO
garbonz's Avatar
Air pressure changes about 1psi for every 10 deg of pressure. So if your tires were at 70 deg F to start they were at 170 deg at the end. What did your TPMS say about temps?
2017 Fuse 23T
