Old 10-18-2012, 07:44 PM   #11
B47
Originally Posted by jackhartjr View Post
Hi folks, a couple of years ago got into a discussion about nitrogen in tires. Someone wanted to get technical on me.
I will say this, we put the Michelin 10-ply's on at 81,000 miles and just replaced them at 176,000. That's 95,000 on that set and they were still just barely legal. I run nitrogen and 50PSI in them.
They were more than 5 years old with no cracking!
Jack
There are a couple threads regarding the pros and cons of using nitrogen in RV tires and looking at it might save everyone sometime and effort.
One thread started 03-07-12 in the General Tech & Repair Forum under the Running Gear, Axles, Brakes, Tires and Frame sub forum and contains 56 posts.
B47 is online now   Reply With Quote
Old 10-27-2012, 07:42 PM   #12
Last time I checked, when the tire was put on the rim it was full of plain old air with moisture in it. Adding nitrogen to pressurize it will NOT make the oxygen or moisture go away.
Hmmm...
joshuajim is offline   Reply With Quote
Old 10-27-2012, 08:11 PM   #13
FNG
fishman's Avatar
Hmmm...
Hmmm...... Good point. I guess they don't mount them in a vacuum. Still, the percentages of O2 and H2O must be much lower.
2012 Wildcat 344QB w/ Outside Kitchen
2011 F350 6.7 Lariat Crew Cab LB SRW FX4
fishman is offline   Reply With Quote
Old 10-30-2012, 09:10 AM   #14
Wanna Be Camper
SaskCampers's Avatar
Hmmm...
There is a special machine that exchanges the O2 for nitrogen in any tire shop I have had it done at.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-30-2012, 09:22 AM   #15
Mine are filled with air and I like being able to top them off at exactly 50 psi before each trip. I had some filled with nitrogen but when checking and finding some variation the only way to maintain the nitrogen level is to haul the camper to the goodyear dealer and pay them to inflate them. I think nitrogen is nothing more than a gimmick promoted by the tire industry as a way for the tire dealers to make more money.
comfun1 is offline   Reply With Quote
Old 10-30-2012, 11:44 AM   #16
Air is 78% N, 21% O and < 1% of other. I would wonder how much difference the 21% O makes? Mine came with N in both the truck and the fiver, but I just add air when filling them.
whj77372 is offline   Reply With Quote
Old 10-30-2012, 11:47 AM   #17
Camper Less Camping
Cajun Po-Boy's Avatar
X2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-30-2012, 08:26 PM   #18
I think you are confusing the "special machine" that generates (separates) nitrogen from the oxygen in air. Otherwise they would have to have tanks of nitrogen. They would have to vacuum the air out of the tire to achieve pure nitrogen.
Actually, NASCAR does this to racing tires, but it takes 3 complete fill and vacuum sequences to achieve it. Been there done that.
NO tire shop does that.
Old 10-30-2012, 08:44 PM   #19
I run 80 psi in my Michelins, and plain old air.
Nitrogen has been proven to be a waste of money.
I have 3 nitrogen-filled tires, and one air-filled because of repair, on my new(er) 1/2 ton, and there is no difference in warm/cold weather pressure, nor loss of air pressure over time.
I just switched the tires on my wife's truck for winter, and those tires that are filled with plain air didn't lose 1 psi over the summer.
I'll take the nitrogen if it is free, but will never pay for it.
bakken is offline   Reply With Quote
Old 10-30-2012, 08:52 PM   #20
This is another subject that keeps coming up and we all prattle on about. It's been a scam since the 50's. I was surprised to see Costco doing it recently - thought they were above that kind of thing, but I guess not.
You see this repeatedly in scams - a morsel of science used to con people out of their money.
crasher is offline   Reply With Quote
