09-14-2013, 12:00 PM
#21
Anacortesians
Based on my research when I worked for Boeing (Landing gear group) you only NEED nitrogen of you can run for 2 miles with a dragging brake, get to 170 mph doing it, and then retract the wheels into a closed box. After about 45 minutes there'll be a big bang.
If you can't do that, it's a waste of money/tire dealer con job.
Frank and Eileen
No longer RVers or FR owners
09-15-2013, 10:18 AM
#22
We use it for tire fill in the aviation world.
Biggest advantage is it is essentially inert.
The other advantage is that it is dry. Meaning: less chance of corrosion inside the assembly. Compressed air also means compressed humidity, which means moisture in the tire/wheel. Nitrogen isn't compressed out of the atmosphere, it is extracted (and damned cold!).
I would think the biggest advantage in an automotive application would be the "dry" part.....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
09-15-2013, 10:35 AM
#23
Had nitro filled tires on my trailer. Now I just fill with regular air. Based on what I read it is a waste of money. Another way to get money out of you for something that was free(air)
2011 GMC 2500HD Diesel
09-15-2013, 11:06 AM
#24
I'm gonna start selling 78% nitrogen to supplement my SS check.
09-15-2013, 02:11 PM
#25
Anacortesians
To clarify my post a little, several airplane tire bursts I studied were actually spontaneous explosions of the gases that built up when the tires got very hot (over 750 degrees). Nitrogen will not support combustion - air will. One 727 incident we analyzed showed a spike in the internal tire pressure to around 12,000 psi that blew rubber and tire carcass debris against the airplane structure and caused an 18" hole.
Frank and Eileen
09-15-2013, 02:20 PM
#26
Guest
Mine came with Nitrogen. All four tires have remained at a constant 50psi, so I have 't touched them. Will use regular air when time comes.
09-15-2013, 02:35 PM
#27
May I suggest that you verify that 50 is what the sticker on the side of your RV says? Sounds a little low to me.
09-15-2013, 02:45 PM
#28
Professional Curmudgeon
Nitrogen is not only a waste of time and money (outside professional racing and the aviation industry), it is sooo old skool!
I'm using helium in the tires of both my TT and TV - it has reduced the tongue weight significantly and increased my GVCW tremendously. Plus, the only time I get tire wear is when they actually touch the ground!
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
09-15-2013, 02:48 PM
#29
And that is the reason the FAA issued an Airwothiness Directive ( in 1989 if I'm correct). After some fires and explosions resulting from overheated brakes in magnesium wheels on large airplanes and the resulting airframe damage, it was determined that air servicing of tires on braked wheels on large airplanes be replaced with nitrogen servicing.
Some of the damage was severe as the fragments from the exploding wheels usually tore up the aircrafts wheel wells and pressure bulkheads.
09-15-2013, 02:55 PM
#30
Yeah but crosswinds would be a whole new shorts staining experience....
09-15-2013, 02:59 PM
#31
Modern aircraft wheels incorporate temperature blow out plugs for this reason.
I'm always replacing them after my AC or FO (usually an FO1) does a "hot brakes" landing....
09-15-2013, 03:11 PM
#32
Actually the blow out plugs requirement come out in March of 1993 which was after the AD came out in 1989. Theblow out plugs were not an AD, but was issued after several incidents involving over servicing of aircraft tires by aviation personnel.
As stated, the plugs were not an AD, but an amendment to 14 CFR 25.733 which added paragraph (e).
14 CFR 25 pertains to the certification standards of large transport category aircraft.
But you are correct that blow out plugs do help elimate wheel explosions from over heated brakes.
09-15-2013, 03:14 PM
#33
Yeah - but those "Hard Landings" on touch down can wipe out any savings in tire wear.
09-15-2013, 04:29 PM
#34
Grape Escape
As long as it makes you feel good. Nitrogen fill is nothing but a way to make some extra cash for the poor auto dealers. Helps them with their yachts, Diesel pushers, and 5000 sf homes.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
09-15-2013, 04:33 PM
#35
Can anyone tell us what they paid for nitrogen tire servicing?
I never had it done, but some posters here say it was expensive in their opinion.
09-15-2013, 07:10 PM
#36
Guest
50psi cold is the max pressure stated on my sidewalls. So if my yellow sticker lists a higher pressure, do I go with that? And I do check them every trip, even with nitrogen in them.
09-15-2013, 07:18 PM
#37
If your yellow sticker gives a higher pressure, someone at the factory made a big mistake (so I don't think it will). It sounds like you're good then. Thanks for checking!
09-15-2013, 07:23 PM
#38
X2
09-15-2013, 07:49 PM
#39
Consumer Reports does not recommend using N2 in car tires, so I suspect they would say the same about trailer tires. I consider it a SCAM for the average car/trailer.
2011 Traverse LT, 3.6L, FWD
09-15-2013, 07:52 PM
#40
one reason acft tires are filled with N2 is the in service pressure, sometime up to 350lbs, plus most acft stay at 32kft and it is -20 to -60 degrees, then the gear door opens and it is landing 40 seconds later and the tire heats up real fast. the pressures are pretty constant with N2. i dont buy into putting it in my truck or 5er. BTW I am a acft mech and pilot, been doing it for over 30 years from c150`s to B747 and fighters
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
