Old 02-13-2014, 02:34 AM   #1
No Trailer Brakes
press brake 2007 c 2500 with built in controller says to check trailer brakes.
Manual apply brake, no brakes. stop reconnect cable, no brakes... lights work. By the time I get to a service center they are closed. As I drive off suddenly I now have brakes. Any Ideas.
Also as a first timer I'm not sure the best way to judge how much to adjust my gain on the controller.
DeanF is offline   Reply With Quote
Old 02-13-2014, 10:10 AM   #2
I like testing on a quite road or in large empty parking lot. Move forward and apply the brakes manually with the brake controller. You will soon get a feel for how well the trailer brakes are working. I will then test the braking "feel" with different controller settings.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 02-13-2014, 10:21 AM   #3
TURBS's Avatar
Sounds like you may have had a ground issue.
Or a connection issue at plug.
If a magnet intermittently doesn't work it will say check plug and likewise if there's a bad ground.
When the integral brake controller is set up properly when you hit the brakes you should slightly feel the back of tv pull down a bit.
Btw this is all in your gm owners manual.
Read 4 thru 7
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-13-2014, 10:24 AM   #4
TURBS's Avatar
This may be eaiser to read.
TURBS
Old 02-13-2014, 10:49 AM   #5
Helmsey's Avatar
This is my first thought as well. I chased brake issues on our last 5er for several months and the ground was the first thing I checked to rule that out.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
brakes, trailer
