Old 12-20-2013, 09:26 AM   #11
Fulltime family RVer
Originally Posted by jonrjen View Post
As for the current weight rating on the OEM tires they are rated at 3520 pounds, so I did under estimate what the factory installed in this area.
What's your actual loaded weight on the axles? And, have you weighed each side/tire individually?
I was surprised to read that there was such a significant loss in load carrying capacity.
Old 12-20-2013, 09:27 AM   #12
jonrjen's Avatar
Tire pressure and temp monitor is a great idea. Since my F350 came with the TPM delete pkg on it, I could add it to my F350 also at the same time. I would just need to make sure that the TPM system I purchased would handle 10 different sensors.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 12-20-2013, 09:34 AM   #13
Herk7769's Avatar
Since there was some discussion about tread design LT vs ST I got some "example photos."
Top one is a typical LT tire and the bottom one is a Marathon ST tire.
Name:	Typical LT tread design.jpg
HAM CALLSIGN - KC3FFW
Old 12-20-2013, 09:38 AM   #14
jonrjen's Avatar
I have only had the trailer in my possession since this last Monday late afternoon so I have not had it weighed at the scale yet. Published weight information is as follows:
Unloaded weight: 10,885
Hitch weight: 1,810
GVWR: 13,810
2013 Wildcat 353LS
Old 12-20-2013, 09:49 AM   #15
Iwannacamp's Avatar
I was taught that the side wall construction on trailer tires was the strength FACTOR. The tire slides a lot on tandem axles. If the weight is good... Then you are OK on the construction, but dual axles create other issues with tire roll-off. IMHO
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 12-20-2013, 09:49 AM   #16
jonrjen's Avatar
Maybe this is more in line with what I am looking for:
Tire Details - Discount Tire
2013 Wildcat 353LS
Old 12-20-2013, 09:54 AM   #17
Denver, CO
garbonz's Avatar
Originally Posted by Dave_Monica View Post
To the OP's original plan. As an alternative, why not purchase a quality tire pressure monitoring system such as TST 507 and keep the OEM tires on the camper. I wouldn't towed anything without a TPMS now regardless what tires are on it.
Dave
The TPMS is a great idea, but may not (will not) react fast enough to prevent damage from a blowout. The sensors operate on a fixed transmission schedule and work well for a puncture and a slowish leak.
These "bad" tires with bubbles and such tend to go catastrophically and even a few seconds delay is enough to cause significant damage. By all means get a TPMS, but also look carefully at your tires before every day of use. Hopefully, there will be some signs of delamination before they come apart.
OR just take the OEM's and toss them and get better ST tires.
2017 Fuse 23T
Old 12-20-2013, 10:29 AM   #18
Hitch weight: 1,810
GVWR: 13,810
Using those numbers, I used my pin weight/estimating calculator and came up with this:
Dry Pin/Tongue Weight Percentage: 16.6 %
Estimated Pin/Tongue Weight Percentage: 19.6 % (3% increase accounting for loading up the front storage)
Estimated Loaded Weight: 12,385 pounds
Weight Carried on Axles: 9,958 pounds
Weight Carried on Each Axle: 4,979 pounds
Weight Carried on Each Tire*: 2,489 pounds
* the weight carried on each tire is greatly simplified here in that I'm taking the # of axles, multiplying it by 2 and then dividing that from the weight carried by the axles. Campers commonly load one side heavier than the other and different tires can carry different weights.
Old 12-20-2013, 10:44 AM   #19
Herk7769's Avatar
Hitch weight: 1,810
GVWR: 13,810
Is that the "Unladen Weight" off the yellow sticker or the "published dry weight"
The Yellow sticker is the actual weight when it left the factory. If your dealer (or you) added anything it won't show up till you actually weigh it yourself.
Old 12-20-2013, 10:48 AM   #20
When I was faced with replacing my camper's tires- the 2 brands/lines that I came down to deciding between were either Goodyear Marathons and Maxxis m8008 tires. I opted for the Maxxis tires, but I'm certain that I would have been happy with the Goodyears.
Supposedly depending on loading and weights, I can exceed 65mph up to about 70mph, but it's a dark day when I need to do it. Otherwise, I'm a 62mph driver.
tire
