Old 06-08-2013, 08:28 PM   #1
jlgail4309's Avatar
One tire getting hotter than the other
One tire getting hotter than the other and showing a lot of wear. The tires my have 3500 miles at the max. Planning before the next trip to put a the new spare on the tv and us the other as a spare.
What would cause so much heat. I was running at max speed of 65 on the high way. thanks for the help
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 06-08-2013, 08:41 PM   #2
Brake problems.
Old 06-08-2013, 08:51 PM   #3
jlgail4309's Avatar
Haven't thought of brake problems thanks will check that out when changing the tire.
Hensley Cub hitch ,
Old 06-08-2013, 09:00 PM   #4
sherdep's Avatar
Could also be bearings are loose
Have you checked to make sure the axle nuts are tight enough for no play but loose enough to allow the tire to spin freely
When I first got my 2011 - it had a loose axle - I mainly noticed it when turning a corner
Had to get a new cotter pin cause the one that was there I broke trying to remove to tighten the axle nut.
While your at it - grease them too of you haven't already.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-08-2013, 09:01 PM   #5
sherdep's Avatar
Loose axle bearing nut. Guess that's what I get for posting from my phone lol
Old 06-08-2013, 09:48 PM   #6
jlgail4309's Avatar
I will check that too. I need to pack the bearings for the first time.
Hensley Cub hitch ,
Old 06-08-2013, 10:11 PM   #7
Twisty's Avatar
"...put a the new spare on the tv and us the other as a spare."
Sorry. I don't get it. Are you asking about the trailer tires or the tow vehicle tires?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-08-2013, 10:18 PM   #8
jlgail4309's Avatar
Sorry put the the spare on the TT. Travel trailer tire looks really worn. I thought maybe it wasn't lined up good. My first travel trailer.
Hensley Cub hitch ,
Old 06-11-2013, 03:45 PM   #9
Check to be sure the shock absorber isn't rubbing on the back of the tire. Mine was/is rubbing on one tire now. Still working the right fix after changing the axles, the tires, and the rims.
Don & Carolyn Koski
2009 34SATS, 2008 F250 Turbo-diesel CC
dckoski is offline   Reply With Quote
Old 06-12-2013, 01:07 PM   #10
Big Bad Allis's Avatar
Maybe low air pressure? That will make it heat up and wear faster
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 06-12-2013, 01:16 PM   #11
How much more hotter ? is it the tire which is hotter or the rim/wheel itself ? Abnormal wear has a lot of reasons as stated above.
Hotter than normal wheel is either a sticking brake, or the other brakes are all not working properly and only the one which heats up is the all the braking for your trailer.
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 06-12-2013, 01:48 PM   #12
Arefbee's Avatar
x2
Work the problem simplest (cheapest) to more complex.
Low pressure
Alignment would be next
Next the brakes.
Could be a poor tire - I had a set of cheaper tires that constantly pulled even after aligning them until I rotated them. Then they pulled the other way. If it is pulling that tire may be the source.
That all said, when you get the wheels swapped have the tire guy test drive it - someone with experience will probably pick out the issue pretty quickly.
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 06-12-2013, 08:21 PM   #13
jlgail4309's Avatar
I changed the tire today. Air pressure was 50 pounds the tire was deformed. Wore real bad in areas. The tire was a lot hotter. So hot did want to leave my hand on the tire. Almost bold in stops on the side tread only on the outside. Priced so new Komho tires. I going to run the spare a litttle while and check for heat. The buy two new ones that are highway rated.
Hensley Cub hitch ,
Old 06-12-2013, 08:43 PM   #14
Just my opinion, but replacing the tire is not going to cure the problem. Found this info on "How to read tire wear" that may apply to your situation.
"Cups or scalloped dips appearing around the edge of the tread on one side or the other, almost always indicate worn (sometimes bent) suspension parts. Adjustment of wheel alignment alone will seldom cure the problem. Any worn component that connects the wheel to the car (ball joint, wheel bearing, shock absorber, springs, bushings, etc.) can cause this condition. Occasionally, wheels that are out of balance will wear like this, but wheel imbalance usually shows up as bald spots between the outside edges and center of the tread."
I realize the article says "car" but I think it also applies to a trailer. We had similar problems and had to replace axles and brackets.
Sirsea is offline   Reply With Quote
Old 06-12-2013, 09:55 PM   #15
DDC
DDC's Avatar
If the tire was deformed then that was the cause.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-12-2013, 10:05 PM   #16
jlgail4309's Avatar
It's still under warranty. If I feel heat in this tire . I will have to take it in for work. I took a long trip to Destin Fl last Christmas. I did know the speed rating was 65. I was doing 70 and 75 most of the way. The tire has looked funny every since.
Hensley Cub hitch ,
Old 06-13-2013, 07:05 PM   #17
H2oski
Measure the diameter of the bad tire and compare to a cool tire. A friend of mine found one of his tires running hot and it was seperating inside. It was larger than the others.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
