Old 06-08-2015, 07:16 PM   #21
French's Avatar
Can anyone tell me the range of this wireless monitor. It is a long way from the back wheels of a 5th wheel to the front seat of the TV. Have read about back up wireless cameras that have trouble producing a good image in the truck because of distance and obstructions in the line of sight. Also can these be purchased locally or just hurt txt online? Thanks!
Dave and Joanne
Southwestern Ontario
2016 Ford F250 Lariat crew cab 6.7 diesel
2015 Rockwood 8285IKWS Diamond
Jokes about German sausage are the wurst
French is online now   Reply With Quote
Old 06-08-2015, 07:17 PM   #22
French's Avatar
Make that thru TST online
Dave and Joanne
Old 06-08-2015, 07:20 PM   #23
I have no problem with the range my 5er is 43 feet long and the truck is a CC F350, I purchased the system through Camping World.
2015 Siera 377FLIK
2014 Ford F350 KR
Molly the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
stevewise is offline   Reply With Quote
Old 06-08-2015, 07:21 PM   #24
HONDAMAN174's Avatar
They make a signal repeater for distances over 50' feet
Just glad to get away
Old 06-08-2015, 07:24 PM   #25
Flybob's Avatar
Originally Posted by Wenatchee Willie View Post
We are not happy with the TST system at all. We have had leaking tires since we put them on. First they were too loose, then too tight. Difficult to find the right position on the sensors. It takes forever for the controller to find all the sensors and this morning after 10 minutes we gave up. The readings are not consistent. First a tire is low, later it is higher, (more than the daytime heating increase, like 20 - 30 psi higher), then that tire is ok and it is another tire. When we took the rv to Les Schwab tire center, one sensor was too loose and we had lost air. The tightened and checked all the other tires and filled them to 80 psi. Rechecked today and all tires are at 80 psi even though the controller is saying one is at 65 and is not even reading one of the other. We would send back for credit if we could, but we are beyond our 30 day return time and did not keep all the original packaging. Just been a pain and not worth it. Will have Les Schwab check the pressures before we head out each time.
Call Truck Systems directly. I had several conversations with them when they first came out and there was little history. They were excellent to deal with.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-08-2015, 07:28 PM   #26
Hi,
Mine works fine with a 36' Silverback fifth wheel.
Rich Phillips
richp is offline   Reply With Quote
Old 06-08-2015, 07:54 PM   #27
Mine works great. No problems at all
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
