Old 05-01-2014, 12:39 PM   #21
ddemme's Avatar
I just recently switched from the OEM P rated tires to Michelin LTX MS/2 LT load range E. The difference in ride quality and handling is huge. Before the switch, I was considering airbags or a helper spring because of the 'squishy' feeling. It turned out that it was the tires, not the suspension. Even with the P rated tires aired all the way up to max sidewall pressure (44 psi), I couldn't get rid of the wallow. The LTs at 45 psi are nice and stiff, and when I'm not towing it's like riding on rails. The ride is a little rougher, but who cares? It's a TRUCK, not a Cadillac.
Drew & Kendra
Lucky & Bentley the camping dogs
2011 Ford F-150 SuperCrew EcoBoost w/tow pkg.
2012 Rockwood Roo 23SS
ddemme is offline   Reply With Quote
Old 05-01-2014, 12:47 PM   #22
Originally Posted by itat View Post
Does the F150 with the max. towing package come from the factory with LT tires or P? I bought it used and it had the current aftermarket tires on it. The previous owner towed a small 5er because it has the rails mounted in the bed.
If I were towing a 5er, I'd probably want LT tires, but for towing my Roo the P-rated tires seem to work just fine. When they are due to be replaced, I'll consider LT tires if they are available in my size, but I'd only switch if there isn't huge difference in price. What does it typically cost to upgrade from a P-rated tire to a LT-rated tire for the same size tire?
Maxtow comes with P-rated unless you spec the LT tires. Only the HD payload comes with LT tires as stock.
LT wood cost more, but the difference is not huge.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 05-01-2014, 01:07 PM   #23
Herk7769's Avatar
Originally Posted by mlong View Post
This thread has me curious now. I have a 2012 Silverado 1500 Crew Cab. The tires on it are Firestone Destination LE tires. I'm trying to figure out if the LE is in between P & LT or something else. Load rating is 2469 per tire and max pressure of 44 psi. I am pulling an Avenger ATI 27bbs. Tongue wt over 600 lbs & TT weight just under 8000 lbs. I don't have any problems with my tires while towing so I think I am fine with them.
Does anyone have any insight?
44 PSI is the "give away." They are P tire equivalents.
LT tires come in load range C - 50 PSI; Load Range D - 65 PSI; Load Range E - 80 PSI; etc...
HAM CALLSIGN - KC3FFW
Old 05-01-2014, 04:43 PM   #24
f5moab's Avatar
Talking
Then there are some Euro metric such as Yokohama A-T/S, 215x70 15, SL rated with a maxx pressure of 51 psi.
But it appears this subject is just like trailer tires vs. non-trailer tires, or Chevy vs. Ford vs. Dodge vs. Toyota, etc. No one is wrong, no one is correct it all depends on the particular circumstances of each application.
f5moab is offline   Reply With Quote
Old 05-01-2014, 05:04 PM   #25
Any brand P tire just does not have the stiff sidewall of LT tires which is the crux of the matter.
Old 05-01-2014, 05:17 PM   #26
f5moab's Avatar
I agree, P-rated tires do not have as stiff of a sidewall as a LT tire (or even an XL tire); however, there are people on here implying it is dangerous to tow a trailer with P-rated tires, and that is not correct in all circumstances.
There are thousands of people towing with P-rated tires with no concerns at all. Just because someone has it in their mind that they will only tow with LT tires...great. But don't try and tell me it is dangerous for me to tow my trailer; it isn't.
And I guess there is NO more for me to say in regard to this subject; so I'll move on. I have no desire to change anyone's mind, since I don't give a darn...
Old 05-01-2014, 05:42 PM   #27
dcheatwood's Avatar
Agreed. P does not have the sidewall strength of an LT, just like gas doesn't have the torgue of a diesel, and a half ton doesn't have the cargo carrying capability of a 3/4 ton, yet they both have a place in towing. :*)
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 05-02-2014, 05:42 AM   #28
member
I have a ? I have a F 150 with max tow pak. with p 275 65 R18 tires with a 44psi max inflation should I max it out for towing or run the 35 psi recommended on the door pillar .I do notice some squirminess would this help Thanks for any advice.
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 05-02-2014, 05:48 AM   #29
B and B's Avatar
As long as you are using any tire with a P rating, you will have a squirmy feeling on the rear end. They will no doubt carry the load, but in an emergency situation like having to swerve to miss something, they could possibly aggravate the situation. LT LR D or LR E tires have a much stiffer sidewall and require a higher air pressure and eliminates the rear end squirm. JMO.
X2 Towed this week in a 40 mph wind off the right side with gusts to 60. 18 Wheelers dog tracking down the road type wind. With the new LT tires the truck stuck on the road.
Nothing to do with weight capacity but stiffer side walls and no squirm. We traded a trailer partially to do with P series tires not knowing any better at first (we also didn't really like the layout either).
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-02-2014, 05:49 AM   #30
B and B's Avatar
X2 Agreed!
tire, tires
