Old 05-02-2014, 05:51 AM   #31
B and B's Avatar
Originally Posted by jdefeo1 View Post
I have a ? I have a F 150 with max tow pak. with p 275 65 R18 tires with a 44psi max inflation should I max it out for towing or run the 35 psi recommended on the door pillar .I do notice some squirminess would this help Thanks for any advice.
I did max it out and it does help with a stiffer ride. The stock tires can tow better but still squirm.
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-02-2014, 06:40 AM   #32
mlong's Avatar
Originally Posted by f5moab View Post
If you mean the 265x65 18 stock tire size, then they are NOT LT, they are P-rated tires.
From what I have seen, on 1/2 ton pickups, the manufacturers are putting on P-rated tires (at least for GM and Ford and what I have seen on the lots).
However, in 18" tires, you do have a decent chance of finding LT tires, if you want.
I do have P rated tires. Next time I purchase tires I will look for LT. That won't be for a while. I bought the truck 6 months ago as a certified pre-owned and new tires were installed at that time.
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
Old 05-02-2014, 06:56 AM   #33
Herk7769's Avatar
Having re-read my posts, while I never said they were "dangerous," I can see where I might have given that impression.
"Dangerous" is a subjective term in this context.
The limited load range of most, if not all, P series tires (when adjusted with the 9% reduction to the load range on the tire while towing), makes them "unsuitable" (objective term) for towing near the max rated load of the tow vehicle.
As I stated previously, I would not tow with P rated tires. (Subjective)
HAM CALLSIGN - KC3FFW
Old 05-02-2014, 07:16 AM   #34
Sgt. Schultz's Avatar
this may offer some clarity TireSafety.com
Along with the chart showing the difference in tire types http://www.tiresafety.com/sizes/trucks/chart.asp
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 05-02-2014, 07:20 AM   #35
Herk7769's Avatar
The note at the bottom of that chart says it all.
The LARGE majority of SUV and Light Trucks will NEVER tow a thing.
Thus the OEM P series tires.
Old 05-02-2014, 11:53 AM   #36
Canadian Member
itat's Avatar
I was thinking the same thing, Herk. I don't personally have any experience towing a trailer that's anywhere near the max. tow rating of my F-150 (11,300#) but I do have several thousand miles experience at, or perhaps slightly over, the max. payload number. With my aftermarket Bridgestone Dueler A/T Revo 2 P275/65R18 tires and an extra leaf spring, it handles the load no problem with no squirminess.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-02-2014, 03:27 PM   #37
B and B's Avatar
I am 9500 lbs with my trailer and cargo on the truck. After earlier this week I can say without a doubt the LT tires dj make a difference. On the same highway commercial hauler towing new RV and 5vers back to Quebec were all over the road with the wind and dry trailers.
Sent from my Z30 using Forest River Forums mobile app
Old 05-03-2014, 07:58 AM   #38
Thank you for all the great responses to my post. Lots of good insight on this subject. In my situation, I think I will give it a try using my new P-tires and use what was recommended on here. I will put in more air pressure and see how squirmy the feel is. I am only planning on a few camping trips this year. My TW is a regular SUV daily driver, so I would prefer to have a smoother ride 95% of the year. If I were to travel more, I think I would consider the LT tires. There are some responses that say they don't make LT tires for a 17" diameter size, which I may not be able to do. Keep your suggestions coming. I pick up the unit today, so I will post how the ride was when I get back.
JWHybrid2B is offline   Reply With Quote
Old 05-03-2014, 01:34 PM   #39
Indymule's Avatar
They make LT tire for 17 inch and 18 inch. II think it is the 20 inch rims that they don't make LT's for.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
2017 Ford F350 Crewcab Dually Diesel
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 05-03-2014, 01:51 PM   #40
B and B's Avatar
I have LT 285 50 R 20 Michelins on my truck. There is also a TA All Terrain available that I know of. Might be others.
tire, tires
