10-26-2016, 11:54 AM
Pay attention to your axles!!
Just wanted to share my story and I'll keep it quick. Long story short, blew a tire back in June on our way home from Disney. Repairs were made to camper and new Maxxis sneakers for the RV (tracer 3200bht). Fast forward to now. Made two trips, Hershey and Luray VA. I normally feel my tires before, during and after my trips. Check air pressure, etc. A friend who is a mechanic was behind me and said, "your trainer feel funny?" We were just about home, so felt safe enough to finish the ride. Once I got home we both noticed the wheel that blew, was wearing funny and had a slight "toe" to it.
We measured between both axles and found a 3/4" difference. Rear axle on driver side was back.
So, take it to a heavy duty spring shop in Richmond, they say I'm lucky because the centering pins on the axles sheared off!! That was causing the axle to "walk" back on the spring.
Needless to say, all fixed now.
They also went through all bearings, other components, checking everything.
So, be aware of your tires and tire wear.
Hope this helps others....
Tom
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
10-26-2016, 12:18 PM
Glad you found what you described before it caused more problems.
It is a shame the 'heavy duty spring shop' didn't do their due diligence in repairing your trailer correctly.
It appears they sledge hammered the axle back into place (see marks on axle saddle in photo # 1) and then instead of replacing the spring center bolt (which the head of the bolt is the centering pin) to keep it in position, they simply welded the the spring to the saddle and replaced the U-bolts.
I can understand doing this as an emergency repair to get you home from a long trip but if you took it there for a diagnosis and repair, this was not a very professional job IMHO.
Also... it takes a HUGE force to 'shear' off a center bolt head. Any possibility you hit a large pot hole or something else when the original tire blew? I realize if you did, the front axle 'should' have taken the brunt of the blow, but who knows?
How are the rest of the center pins? Did anyone check them?
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-26-2016, 12:26 PM
Too old to be too smart
I believe the Banjo Man has this one summed up nicely.
A "schlock" fix, at best!
Now you should go get it fixed correctly.
Yup! Pay attention to your axles!
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
10-26-2016, 12:29 PM
I think they more than likely made a repair to the saddle with a plate welded on and it does not appear to welded to the spring. They did this most likely because if the center pin sheared, it probably destroyed the saddle also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
10-26-2016, 12:33 PM
The shop is who diagnosed and fixed the issue. Great place, been in business for over 100years.
They replaced the centering pin, at least that's what i was billed for and was told by the mechanic doing the work.
I don't remember, that's the issue. The mentioned that i must have made a turn into a pot hole to shear the pin, since that's what the pin is meant to do so you don't rip the shackle off the frame!!
They checked the front axle as well as checked the alignment and correct that one as well.
Overall, i'm very pleased with the work they did. I feel MUCH safer going down the road now. I was very nervous heading to the shop from my house knowing what the issue "could' be after diagnosis by my mechanic buddy.
10-26-2016, 12:35 PM
While I agree that that is an added plate (not the same amount of rust as the spring packs), the added thickness to one perch alone will slightly throw off suspension characteristics, and possibly contribute to even more alignment problems going forward.
As our pickin' compatriot alluded, this isn't a proper solution.
You have a wrong idea of the purpose the spring-pack center pin. It's not meant to be sheared off at all.
Pop
10-27-2016, 04:11 PM
That is an "inordinate" amount of rust on both the suspension, and the axle. Should be no mystery what happened to the center bolt.
10-28-2016, 01:54 AM
I believe the shop did a proper repair. Everyone is making assumptions that are not justified. No frame shop that has been, or is, in business would only plate one side of an axle, although that is what we are seeing because of only one pic. I'm sure they equaled it out and aligned them after the fact. The only other alternative would have been a new axle. I would have accepted the repair, although I would have done the repair myself.
10-28-2016, 05:58 AM
The repair looks just like the work my father and I did in 1978 rebuilding the axles on his trailer.
Good job getting the shop to repair this and for a friend seeing the problem.
B and B
10-28-2016, 07:49 AM
Pop
The added thickness means nothing as far as alignment. Think water heater full of water vs empty. That would cause the difference of the thickness of the plate in running level or not. Or even loading 2 cases of beer in the cupboard.
Also for the op. Then bolt holds the spring pack together and centres it on the perch somewhat. Measurement should be the rule for alignment though.
B and B
10-31-2016, 06:52 AM
Yes, you are correct. They did the same repair on the passenger side. Now, my buddy who is a master ase technician, would have done it for me, but we were at my house, about 60 miles from his, where he has all the tools. This shop was only a 12 mile ride from my house, which i took very slowly down i95.
10-31-2016, 06:57 AM
Super annoying seeing all that rust. I feel i should be back in New England!
What are you or the 'FROG's" doing to their components under the rigs? Wire brush and some black rustoleum paint?
