Old 04-12-2014, 10:30 PM   #11
Post
Originally Posted by BigJohnD View Post
In regards to torque, what is the proper torque for the 5/8 inch Grade 8 bolt, non-lubricated? Right now, they are at 150 ft / pounds, which is probably a shade low. I've seen specs from 150 to 230. I staged them up to 150 via hand tight, wrench tight, 50, 100, 125 then 150. If they need to be a shade higher, not a big deal. All were torqued with a Snap-On torque wrench, so not a cheapo by any means.
5/8-11 Gr 8 Dry 230Max
So at 150 Dry, you're good to go!
http://www.engineershandbook.com/Tables/torque.htm
Old 04-12-2014, 10:32 PM   #12
jevanb's Avatar
I TQ mine to 150ftlbs , according to the Structural repair manual of the 727 Tq specs I have at work for the said fasteners. No reason to step TQ, just tighten down then TQ in a fluid motion , not jerky or stopping. Never do we step TQ any fasteners in the acft field and I have never seen it done in 31 years , even when I was working at the factory (McDonnell Douglas defense) for a short time.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-12-2014, 10:44 PM   #13
Plain Old Member
Thanks for the info. 150 it'll be then. Maybe not necessary to step torque, but, if nothing else my arms got a small work out.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 04-12-2014, 10:48 PM   #14
Might not be necessary to step torque, but I always have and do. Started when building engines on head bolts, rods, mains, lug nuts, etc.
Old 04-12-2014, 10:51 PM   #15
Oklahoma Proud
MillerTime's Avatar
X2.
Some of specs call for it
MillerTime- Future Sabre Handler!!
Old 04-12-2014, 10:52 PM   #16
Plain Old Member
Kind of where I got the habit from. My brother-in-law does a lot of the engine building / hot rod stuff.
