Old 04-10-2014, 09:22 PM   #1
Plain Old Member
Pin Box Bolts - Quantity and Grade
I've looked at 100's of fifth wheels over the years, and noted the way each pin box is mounted. I find it interesting that some manf use 8 bolts, and some use 10 on the pin box. I never understood why they would use only 8, when there are 2 more holes ready to accept bolts in most occasions. I also never understood why they used grade 5 bolts. Maybe from an engineering point of view, that's all you need. My SB came with 8 grade 5 bolts. I guess to give myself the warm fuzzy feeling, I changed them all out for grade 8 hardware, and added 2 more bolts for a total of 10.
Now, at least if my lippert frame cracks or breaks around the pin box, the pin box will stay attached to the piece that breaks off. Yes, being sarcastic, but it's happened too many times as you'll read on this forum.
ID:	49589   Click image for larger version
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 04-10-2014, 10:39 PM   #2
jtstromsburg's Avatar
Not likely, but its possible the g5 bolts are used due to g8's being more brittle? Doubtful that's the reason, but they are.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 04-11-2014, 09:04 PM   #3
Plain Old Member
Maybe so. I know they put grade 8 on the level up jacks, but they don't see the shock that the pin box does. I think the grade 8 on the pin box will be fine.
Old 04-11-2014, 09:10 PM   #4
I'd agree completely. Good to add the extras like you did too. I'll be checking mine.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
Old 04-11-2014, 09:22 PM   #5
It is all about the right tool for the job. Grade 5 will stretch before they break. That makes them more suited for the pin box due to the "shock loads" the pin box in likely to see. Yes, the grade 8 have a stronger tensile strength, but when they fail, they shear. Shearing is a bad thing when it is the hitch! In the case of the Grade 5 bolts, when the start to fail, they bend/get misshapen, but at least the hitch it is still connected. Hopefully you would notice the misshaped bolt(s) before they failed. With Grade 8, looks good one day, sheared the next. Ten vs eight probably comes down to rated load. No reason to not do ten, other than RV manufacturers are cheap!
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 04-12-2014, 09:44 PM   #6
Plain Old Member
Good to hear all the input on Grade 8. I'm going to leave them in there and take my chances. I just don't see how 10 - 5/8 inch grade 8 bolts would shear with 2600 pounds on them, but it's possible I suppose. I figure the lippert frame is the weak point on this rig. With my luck so far, I'm waiting for a cracked frame around the pin box any month now.
Old 04-12-2014, 09:47 PM   #7
Ford Idaho's Avatar
I'm kind of sure the welded frame would cave before the pin box bolts sheared.
Old 04-12-2014, 10:04 PM   #8
The gr 8 bolts are much better for shear loads than gr 5 and the pin box is strictly in shear. Good choice. Just make sure you torque them to the proper torque and DO NOT OVER TORQUE them.
Shear is normally 60% of tensile strength. Gr 5 has a tensile strength of 120,000 lb min. Gr 8 has a tensile strength of 150,000 lb min.
Old 04-12-2014, 10:06 PM   #9
jevanb's Avatar
I added AN hardware to my pin box, I did not like the threads in the hole and or extra washers on the head and nut to get the correct grip. I sized my according to the grip length, plus the QTY control of SAE bolts ae something to be leary of.
AN (aircraft) fasteners are manufactured to rigorous quality control standards from raw material to final plating
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-12-2014, 10:15 PM   #10
Plain Old Member
In regards to torque, what is the proper torque for the 5/8 inch Grade 8 bolt, non-lubricated? Right now, they are at 150 ft / pounds, which is probably a shade low. I've seen specs from 150 to 230. I staged them up to 150 via hand tight, wrench tight, 50, 100, 125 then 150. If they need to be a shade higher, not a big deal. All were torqued with a Snap-On torque wrench, so not a cheapo by any means.
