Old 04-04-2015, 07:39 PM   #1
power jack
i know this has been beat to death and i did do a search and i went through a ton of good threads but they were old.
what is the best power jack on the market?
my thoughts are to go with Barker's Deluxe Hi-Power 3500 lb. Jack but we usually just haul the camper to the lake and park it and maybe 2-4 trips through out the year so should i go with something a little cheaper?
i know you get what you pay for and i only want to do this once. Thank you for the help
Knepp1bj is offline   Reply With Quote
Old 04-04-2015, 07:52 PM   #2
mark0224's Avatar
Made my own using the crank jack that came with the trailer, took crank off bought a bolt drilled a hole in it then put it where hand crank was and put the roll pin in the drilled hole. Then I use the drill that I put the stabilizer jacks down with. If something goes wrong with drill I have a ratchet that I can use . Always carry a couple of extra roll pins. Cost of this one less than a dollar, since I already had drill.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 04-04-2015, 08:13 PM   #3
Bought a bolt or a nut and drilled a hole it it?
Old 04-05-2015, 05:59 AM   #4
mark0224's Avatar
The bolt replaces the hand crank in the original jack.
Bought a 3/4 inch x 3 inch bolt drilled a hole in the shank to receive the roll pin that drives the jacks gear. You then use your drill and 3/4 inch nut driver to make the jack go up and down. On my old trailer I could use a 3/8 inch 18v rechargeable drill on my v lite I needed a little more kick so I got a 1/2 inch low speed high torque corded drill from Harbor freight.
After buying the drill total cost was $ 51 and I use that drill for all the jacks. Originally had planned on using the drill I had like on our old unit .
Old 04-05-2015, 06:17 AM   #5
Can you take a picture? I've never seen a tongue jack with a 3/4" dia shaft for the horizontal gear. If you are using a 3/4" socket, then the bolt would be 1/2" dia.
Old 04-05-2015, 06:23 AM   #6
mark0224's Avatar
shank is 1/2 inch on bolt sorry Thought I put it in.
Old 04-05-2015, 06:40 AM   #7
Thanks, was confused when you said 3/4 x 3". Doesn't take much to confuse this old man.
Old 04-05-2015, 10:19 AM   #8
well that is one way...anyone else have any ideas about a power jack?
Old 04-05-2015, 10:25 AM   #9
spierce617's Avatar
Where did you get the levels that are shown in the picture?
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-05-2015, 10:27 AM   #10
ebay and search for "power tongue jacks"
power
