Old 08-01-2013, 09:09 PM   #41
BeagleIL's Avatar
Originally Posted by garbonz View Post
you should be lifting the tongue weight off the truck, but not lifting the truck itself, although at 3500 capacity it shouldn't matter.
Definitely lifting more than the tongue weight. To get the bars to slide onto the brackets easily, the bed of my truck gets about 4 inches higher than when the truck sits by itself. So I've got my trailer's tongue weight and then what ever it takes to lift my truck. I'm no where near lifting the tires off the ground. But it could be in the thousands of pound range.
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
Old 08-09-2013, 06:03 AM   #42
Taranwanderer's Avatar
X2. You're definitely pulling up on the back of the truck to install the Equalizer bars. I have a Barker 3000VIP that is slowly giving up the ghost--the switch went on it, Barker sent me a new one free of charge, and it's still cranking. But when it goes, I'm going 3500 or higher--using the EQ definitely will shorten the jack's life. Overkill is good, in this case.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-09-2013, 10:10 AM   #43
Triguy's Avatar
Although the Barker 3500VIP can lift the weight of the tongue plus back end of my truck, I don't think the system should be used consistently to lift it high enough to get the bars on easily (by hand).
I just jack high enough to use the snap-up lever from Equal-i-zer.
Taranwanderer, my switch recently failed on my Barker also and they sent me a replacement for free, as well. Good service from Barker!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-10-2013, 08:06 PM   #44
Absolutely. Very good customer service. They sent me a switch, I pulled out the fuse when I installed it but at some point managed to blow the fuse anyway--when I called Barker's customer service, they explained how to test the motor, I did, and eventually figured out what was wrong. Really nice people to deal with.
