Old 11-16-2013, 02:38 PM   #1
pulling new trailer with a ford ranger
i'm buying a new Rockford 2109s 21 foot. the dry trailer weight is 3665 lb., and the tongue weight is 336 lb.. my ranger has a towing capacity of 5700 lb. it has the towing package, and the 4.0 v-6. the dealer sold me an equal-I-zer 1000 system. and is installing the brake controller. I don't plan on long hauls mostly close to home. just to old to travel far any more. my ranger is a 2011 with 17,000 miles and has no problem pulling the 2700 lb. camper I have now with 360 lb. tongue weight. does this new set up sound feasible? thanks bill
wpredock is offline   Reply With Quote
Old 11-16-2013, 03:29 PM   #2
raspivey's Avatar
That 1000 is overkill and may actually be a worse ride ( the dealership will try to tell you otherwise....it's better to treat them like a used car salesman and research anything they say). Too much spring stiffness can result in unpredictable ride and bounce. I've got the other floor plan of that trailer and I can tell you you'll probably be around 4300 lbs. and 460 lbs on the tongue loaded so, if it were me, I'd get the 600 / 6000 lb model instead of that 1000 / 10,000 lb. (probably something they keep in stock for the larger trailers and probably more common than the smaller unit) That is, by the way, the hitch Equilizer recommended (90-00-0600)when I punched in the weight numbers for your trailer on their website. If the dealer won't order it, get it online. The truck will pull it, just expect around 10 mpg....that's what I get with a 4.2L. Also, depending on your wheelbase...and I think you're about the same as me, the crosswind can be a beast. Sway shouldn't be an issue, but it tends to want to push me around a little, so watch out.
Old 11-16-2013, 03:38 PM   #3
bikendan's Avatar
well, without knowing which cab you have, which rear end ratio you have, which trans you have, whether it 4x2 or 4x4, can't say for sure if you have the 5700 towing capacity.
but if you do, you should be fine on hitch weight and trailer weight, since the GVWR is well below the 5700 number.
BUT don't use fictional "dry" weights. no trailer weighs its brochure/website "dry" weight from the factory. those are stripped down trailer weights and bear no resemblance to what they actually weigh.
i suggest you get the yellow sticker weight of the trailer, which will be its actual weight when it left the factory. it won't include battery, water, cargo and maybe propane weight.
by the way, what did your dealer charge for the controller/installation and Equalizer, if you don't mind saying?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-16-2013, 03:50 PM   #4
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Four years ago I began my RV journey using a Ranger pulling a 3500 lb. 21' Passport by Keystone. It pulled ok, but here's a warning. Get a good pair of side view mirrors. The Ranger is pretty narrow and seeing around behind you is difficult if not impossible without a good set of mirrors. I bought some at Camping World that fit on the side of the doors and extended way past the factory mirrors. Did not even consider those that just fit on the mirrors. Also get a weight distribution hitch. You won't regret it. By the way; I now have a F250 and a fifth wheel. I guess you can say I got the RV fever real fast. Good Luck and Welcome to the forum. Hope to see you around.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-16-2013, 03:59 PM   #5
While trailer shopping recently, I ran into several dealers selling "Equalizer/Equal-i-zer" hitches that were NOT the brand name hitch at all, they were lesser quality hitches.
Big dealers, and very blatant about it.
woozy is offline   Reply With Quote
Old 11-17-2013, 02:46 AM   #6
thanks all for the great info, i kind of started out big with 2, 5th wheels and a ford 1 ton v-10. since i happen to have his and hers rangers now, i had to down size big time. i'm going to confront the dealer on the equilizer hitch size. the ranger i'm pulling with is a super cab, with an automatic , with a 3.70 rearend. they are installing a proportional brake control for $179.00. bill
Old 11-17-2013, 06:58 AM   #7
rycej's Avatar
I pull a 3700 lb trailer with my 2011 Ranger. It can handle it for short trips but boy does it suck for gas. I find the Ranger is bad on gas on a normal day but with the trailer, yikes. I've done a few trips with it. Once I stayed on the secondary highways where I stayed at around 80 Kms per hour. Other time I drove on the main highway where I drove at 100 Kms per hour. Seemed I used less gas when staying at the slower speed. I also had a bit of a hard time getting out of a dry camping area when the "road" was slick with mud, so I know to avoid that situation as much as possible.
I have a 600/6000 WDH and the extended mirrors and it seems to work.
2013 F150 v8 4x4 Supercab
2014 Surveyor 192T
rycej is offline   Reply With Quote
Old 11-17-2013, 08:25 AM   #8
I'm coming up at 79 so I have a few years to go before I get to old to travel!
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 11-17-2013, 09:49 AM   #9
sounds like your having a great time. i just can't drive that far anymore. we stay close to home. if i thought i was goiing to get this old i would have changed my oil more often.
Old 11-17-2013, 10:14 AM   #10
If you run into a certain Iowegian, you won't even want to leave home.
trailer
